Your Welding Job Search: Recruiters, Roles & Real Pay
A hub for finding welding jobs, vetting recruiters, and comparing pay by specialty.
The U.S. Bureau of Labor Statistics tracks 416,210 welders, cutters, solderers, and brazers, with median wages ranging from the low $40,000s in lower-cost states to over $80,000 in Alaska and $79,000 in Hawaii. Pipe welders, structural welders, and fitters each command different rates, and metro premiums in Baton Rouge push median pay to $78,170, with top earners near $79,880.
The friction for most job-seekers is not demand. It is matching the right certification stack (AWS, ASME Section IX, API 1104) to the roles hiring in their region, then getting past weld tests, drug screens, and TWIC requirements before a paycheck starts.
Welding Job Roles: Structural, Pipe, and Fitter, What Each Does
Most welding jobs fall into three distinct roles, and choosing between them changes where you work, what you weld, and which welder certifications matter.
Structural welder
Structural welders join beams, columns, plates, and bracing for buildings, bridges, and industrial frames. They work outdoors on job sites or in fabrication shops, often at heights or inside partially erected steel. Core processes include stick welding (SMAW) and flux-cored arc welding (FCAW). Employers usually want an AWS D1.1 structural welding test, but pipe certifications are rarely required.
Pipe welder
Pipe welders work on high-pressure piping in refineries, power plants, and chemical facilities, and take on shipyard welding jobs. They weld in tight positions, including 6G, and must produce x-ray or ultrasonic quality welds. This role commonly requires ASME Section IX or API 1104 pipe certifications, plus employer-specific tests. It pays more on average but has a higher barrier to entry and more travel.
Fitter
Fitters read blueprints, lay out parts, cut and bevel, and tack assemblies so welders can complete the joint. In shops and shipyards, a fitter may also weld final passes, while field fitters focus on alignment, fixturing, and grinding. A fitter usually needs a strong layout and math foundation plus an employer welding test; pipe fitter roles may add pipefitting or rigging credentials.
Among the three, pipe welding demands the most formal certification, structural welding has the broadest entry path, and fitting rewards blueprint and layout skills.
Entry-Level Welding Jobs: Requirements, Screenings, and How to Get Your First Job
The phrase "entry-level" trips up more first-time welders than any weld test, because employers use it to mean very different things. Some entry-level postings expect a year or two of shop time; others genuinely train from zero. Learning to read that distinction saves you from wasting applications.
No-Experience vs Entry-Level
A true no-experience role means no prior paid welding job, not zero ability. Employers still screen for aptitude, shop-class exposure, tool familiarity, safety awareness, and physical capacity. Valmont's solar welder roles, for example, take applicants with no prior welding experience and provide training, asking mainly for a high school diploma or GED. Huntington Ingalls runs a welder/structure trainee track of about 120 hours over three weeks3. By contrast, General Dynamics Electric Boat lists "entry level" but expects roughly two years of experience and a destructive bend test4. Read the fine print before applying.
Common Screenings
Requirements vary by employer, worksite, and industry, but several checks show up repeatedly:
  • Background check: Standard at defense, shipyard, and manufacturing sites like Nucor5 and Huntington Ingalls3. Scope varies.
  • Drug testing: Common in industrial, shipyard, and federally regulated work. Nucor uses urinalysis and hair follicle testing after a conditional offer5; federal Navy positions screen for marijuana7.
  • TWIC card: Worksite-dependent, tied to secure maritime and port facilities. Ordinary manufacturing and most construction jobs do not require it. Note the TSA assessment behind a TWIC does not include a drug test6, so that is a separate step.
  • Weld test and physical agility test: Nucor5 and Electric Boat4 require practical weld tests; Huntington Ingalls adds a physical agility test3.
  • Citizenship: Federal and defense positions often require US citizenship and E-Verify7.
Typical Minimums and How to Apply
BLS classifies welders as needing a high school diploma or equivalent plus moderate-term on-the-job training, with no universal prior-experience requirement1. Bring a certificate, tech-school record, or apprenticeship history if you have one; if you don't, target employers that advertise training. Show up ready to pass a weld test, and search welding jobs and fitting jobs or apply directly to manufacturers and shipyards hiring trainees.
Welding Certification Cost and Requirements: AWS, ASME, and API Explained
Welding certifications are not a single permanent license. They are tied to specific processes, positions, and often to the employer or project. The table below compares the most commonly requested credentials for structural, pipe, and shipyard welding roles.
CertificationIssuing BodyTypical CostTimelineEmployer Expectations
AWS Certified Welder (CW)American Welding Society (AWS)$70 application fee plus $105 yearly maintenance subscriptionAnnual maintenance subscription; continuity commonly documented every six monthsPosition- and process-specific qualification; employers expect documented continuity or requalification after a break
ASME Section IX Welder Performance QualificationAmerican Society of Mechanical Engineers (ASME)$0 to $200 test fee when employer-sponsored; total estimate $0 to $500Tied to the welding procedure; requalification required after six months without welding under that procedureEmployer-issued or third-party Authorized Inspector under a Welding Procedure Specification; common for pressure-vessel, boiler, piping, and code-controlled work
API 1104 Welder QualificationAmerican Petroleum Institute (API)$400 to $900 per performance test, varying by position and testing requirementsProject- and procedure-specific; requalification required when continuity or employer requirements are not metCommon for pipeline, transmission, distribution, and oil-and-gas welding; may require radiographic or bend-test acceptance
AWS Certified Welding Inspector (CWI)American Welding Society (AWS)Third- and sixth-year renewal by work experience: $650 for members or $915 for non-members; by examination: $1,040 for members or $1,305 for non-members; two-week or eight-week online seminar: $2,245 for members or $2,510 for non-members, plus a $1,500 refundable depositRenewal at third and sixth years; nine-year recertification via course or examCommon for welding inspection, quality assurance, and quality-control roles; active credential often requested for code-compliance inspection work
Welder Pay by State: Median Salaries and Employment
Median annual wages for welders, cutters, solderers, and brazers vary widely by state. The table below shows the states with available data, ranked by median annual wage. Alaska and Hawaii lead at $80,840 and $79,000, while California, Wisconsin, and Louisiana report the largest employment figures.
StateTotal EmploymentMedian Annual Wage
Alaska79080840
Hawaii52079000
Connecticut179064880
Wyoming185063820
Washington772063020
Massachusetts283062570
New Hampshire111062360
Louisiana1369062250
Maine169062220
North Dakota259062000
Nevada160061520
Vermont34060890
Maryland285060310
Minnesota927060280
District of Columbia28060180
New Mexico239059840
Oregon524059450
New Jersey373059440
Virginia1010059180
New York831059140
Colorado497058590
Wisconsin1532058410
Utah444058380
California2606058060
Delaware60057270
Highest-Paying Metro Areas for Welders
The table below lists the largest metropolitan areas for welders, cutters, solderers, and brazers, ordered by total employment. Median and mean annual wages are included to help compare pay across metros. Baton Rouge, LA stands out with the highest median wage among these areas, while Houston, TX offers the largest number of welding jobs. Keep in mind that high cost metros like New York and Los Angeles may require higher pay to offset living expenses.
Metro AreaEmploymentMedian Annual WageMean Annual Wage25th Percentile75th Percentile
Houston-Pasadena-The Woodlands, TX15,85057,94059,53046,47071,460
Dallas-Fort Worth-Arlington, TX10,62051,63055,89046,18062,670
Chicago-Naperville-Elgin, IL-IN9,32052,65056,18046,27061,750
Los Angeles-Long Beach-Anaheim, CA7,85056,16060,12047,91064,800
New York-Newark-Jersey City, NY-NJ5,78061,68067,43052,79075,930
Phoenix-Mesa-Chandler, AZ5,44056,54059,97048,89065,690
Atlanta-Sandy Springs-Roswell, GA5,24049,63053,31046,13059,700
Philadelphia-Camden-Wilmington, PA-NJ-DE-MD4,63058,38060,65049,70068,890
Minneapolis-St. Paul-Bloomington, MN-WI4,60061,88063,30055,02072,140
Detroit-Warren-Dearborn, MI4,58051,81055,90047,65061,010
Tulsa, OK4,52053,55055,54047,60061,810
Riverside-San Bernardino-Ontario, CA3,81052,05057,32047,83060,850
Virginia Beach-Chesapeake-Norfolk, VA-NC3,74062,67062,00049,95071,090
Baton Rouge, LA3,69078,17072,43061,17079,880
Pittsburgh, PA3,60053,61057,52047,48063,120
Welding Recruiters and Staffing Companies: How to Use Them Without Wasting Time
The tradeoff with recruiters comes down to speed versus control: an agency can put you on a paying job in a week, but you give up some negotiating leverage and often a slice of your hourly rate.
How Welding Staffing Agencies Actually Get Paid
Welder staffing companies do not charge welders a fee. They bill the client shop a markup on top of your wage, typically 25 to 60 percent. That means if the shop pays the agency $45/hour for your labor, you might see $30. The gap covers payroll taxes, workers' comp, and the recruiter's margin. Direct-hire recruiters work differently: the employer pays a placement fee (often 15 to 25 percent of first-year salary) and you go straight onto the company's payroll at full rate.
When to Call a Recruiter vs Apply Direct
Use a staffing agency when you need work fast, want to try a shop before committing, or are chasing travel, shutdown, and maritime agency welding jobs where the agency handles per diem and logistics. Apply direct when you already know the employer, want benefits from day one, or are targeting union halls and apprenticeship programs, where a recruiter adds nothing.
Avoiding Duplicate Applications
The same job often appears three or four times: once from the employer, once each from two agencies, and once scraped onto an aggregator. Track every application in a spreadsheet with the job title, city, and date. If a recruiter pitches a role, ask which company before you say yes, so you do not get submitted twice and disqualified.
Building a Recruiter Relationship
Pick two or three recruiters who specialize in welding or industrial trades. Send updated certs, a current TWIC status, and your travel radius. Answer their calls quickly. Recruiters push the welders who make them look reliable.
Travel Welding Jobs: Compensation, per Diem, and What to Expect
Local shop welding means steady local hours and a familiar commute. Travel welding trades that for higher total packages built from hourly pay, overtime, per diem, and often paid travel. The tradeoff: you follow the work for weeks or months at a time.
How Travel Welding Pay Is Structured
Most travel welding pay is not a single wage. A package may combine base hourly pay, overtime, and daily per diem. In 2026, travel welder hourly rates commonly run from $25 to $55.08 before overtime, and per diem often falls between $75 and $180 per day, with some listings reaching $210. Mileage reimbursement, when offered, may be around $0.725 per mile.1 Overtime varies: some postings depend on client demand, while Ironworkers Jobline may list overtime at base times 1.5 after 10 hours daily or 40 weekly. Do not assume overtime is guaranteed or always time-and-a-half unless the offer says so.
Per Diem: Lodging and Meals
Per diem generally covers lodging and meals while away from home, but it is not a standard wage. The GSA Per Diem Bulletin FY2026 reference rate is $110 per night for standard U.S. lodging and $68 per day for meals and incidentals, a combined daily reference of $178. Employers do not have to follow that. Private examples range from $70 to $210 per day, and conditions vary: some require a minimum distance before a higher per diem applies; others pay travel and hotel separately. Treat per diem as a reimbursement-style benefit, not base pay, because tax treatment and eligibility differ by employer and project.
Travel vs Local Shop Pay
Travel compensation usually exceeds local shop pay because non-wage benefits add up. A 2026 salary guide estimates entry and production welder earnings around $39,240, while traveling turnaround and rig welders are estimated around $77,530, a difference of roughly $23,780. Those are annual estimates, not direct hourly comparisons, and per diem often reimburses living costs rather than adding to take-home wages. Still, local shop work usually lacks lodging, meal per diem, paid travel, and heavy overtime, so travel roles frequently offer the stronger total package.
Common Industries and Locations
Travel welding jobs cluster in pipeline work, power generation, industrial construction, refinery turnarounds, semiconductor projects, and manufacturing outages. Demand appears strongest in the Midwest, Gulf Coast, and regions with major plant maintenance cycles. Roles commonly include pipe welders, structural welders, and combo welders on contract or temporary-to-hire assignments.2
Shipyard Welding Jobs: TWIC, Security Clearance, and Shop vs Shipyard Work
Shipyard welding means building or repairing vessels, from Navy destroyers to commercial tankers, working inside cramped double-hull compartments, on scaffolding over open water, or in dry docks exposed to weather. The work is dirtier and more physically demanding than shop welding: confined-space entry, overhead positions, and constant ventilation and fire-watch requirements, core Welder Safety practices, are the norm, not the exception.
The TWIC Card
Almost every shipyard requires a Transportation Worker Identification Credential (TWIC) before you can walk through the gate. It's issued by the TSA after a background check and fingerprinting, costs around $125 to $150, and takes several weeks to process. Apply early, before you have a job offer in hand, because employers often won't hold a start date while you wait on federal processing. Some Navy and defense-contractor shipyards also require a security clearance or at least a favorable background check, which adds time and rules out applicants with certain criminal histories.
Shop vs Shipyard
Shipyard welders typically test on more positions (vertical, overhead, out-of-position pipe and plate) and carry certifications tied to naval or ABS standards rather than general structural codes. Pay tends to run higher than comparable shop work because of the physical demands and clearance requirements, and shipyard contracts often mean steadier, multi-year work tied to vessel construction schedules rather than single-project shop jobs.
Common Employers and Locations
Major shipbuilders cluster around coastal and river hubs: Newport News and Norfolk, Virginia; Pascagoula, Mississippi; Groton, Connecticut; and the Gulf Coast around Louisiana and Texas. Both prime contractors and their welding subcontractors post openings regularly, including Shipyard Apprenticeship Programs, so it pays to watch several employers in the same region at once.
The Welder Career Pathway: From Entry-Level to Specialty
Most welders advance by stacking certifications and logged hours, not by waiting for a title change. The typical path moves from helper or trainee through a certified welder role into specialty work such as pipe or underwater welding, with each step adding both responsibility and earning power.
Welding career path from entry-level helper and trainee to certified welder, specialty pipe welder, and underwater welder.
Union vs Nonunion Welding Jobs: Pay, Benefits, and Apprenticeship Terms
Union and nonunion welding jobs can both lead to solid careers, but they differ in pay, benefits, training, and job security. Union agreements tend to bundle higher base wages with pensions and healthcare, while nonunion shops often offer more flexible entry and employer-specific training.
Comparison areaUnion welding jobsNonunion welding jobs
Median weekly earnings for construction workers, 2025$1,585$1,132
Reported welder pay package, 2026$72,300 in wages plus about $22,000 in benefits and pension$48,500 in wages plus about $8,000 in benefits
Civilian workers with employer medical benefits, 202495%72%
Apprenticeship structureUnited Association program runs 60 months at about 2,000 hours per year; Boilermakers apprenticeship runs about four yearsVaries by employer; often shorter on-the-job training without a registered apprenticeship
Apprentice payOften starts at 50-60% of journeyman wage, with scheduled increasesVaries by shop and location; no set scale
6G qualification costsUsually covered by the apprenticeship or employer$4,000 to $9,000 out of pocket to obtain and maintain a 6G qualification
Retirement benefitsPension and health, dental, and vision benefits often included401(k) matching is common; retirement benefits vary
Job security and advancementStructured apprentice-to-journeyman progression, with union agreements often governing layoffs and recallsAdvancement is employer-driven and can speed up or stall with shop workload
How to Spot a Real Welding Job Posting: Direct Employer vs Staffing Agency Reposts
A direct employer posting will survive a quick verification trail: check the company careers page, the recruiter email domain, the person’s LinkedIn profile, and the company’s main phone line.1 If any of those don’t match, treat the ad as unverified. The ad itself should name a hiring manager, a specific worksite, shift pattern, welding process (such as MIG welding), position, material, and certification requirements, AWS D1.1, ASME Section IX, or a 6G pipe test.2 A vague description with no named site or process is usually a staffing repost or a recycled listing.
Staffing agency reposts can still be legitimate, but they frame the job differently. Look for phrases like employer of record, temporary, contract, or placement; those tell you the agency, not the site, will be your employer.3 Screening will focus on certification verification, resume review, phone screening, reference checks, and immediate availability.4 That’s not automatically a red flag, many companies use agencies for pre-hire screening, but it changes who you need to verify.
Stop at the same red flags in either format: vague or copy-paste text, a single-board listing, urgent start-tomorrow language, and upfront fee requests.5 Avoid sending bank details, passport copies, government ID, or any fee before a written offer.6 Duplicate clues include the same wording, pay, and location under different company names, inconsistent branding, or a listing that reappears without a company page trace.5 If a welder job appears on only one board and asks you to start tomorrow, slow down.
A legitimate staffing agency can still be a real path, but only if the company is real, the recruiter identity checks out, and you can verify the assignment site. Use the same direct-employer sequence: company careers page, recruiter email domain, LinkedIn check, and main phone line. If the recruiter will not connect you with the actual worksite or hiring manager, walk away.
How to Evaluate Welding Job Offers: Pay, Benefits, Safety, and Union Terms
Most welding job offers include an hourly base rate, but overtime and per diem can add 20% to 40% to take-home pay. Start by comparing the total package, not just the posted wage.
The Four-Part Offer Checklist
  • Hourly pay: Is it straight time or does it include shift differentials? Ask what the overtime rate is and how many hours are typical.
  • Per diem and travel: For travel or shipyard jobs, confirm daily per diem, lodging, and whether per diem is paid for days off.
  • Benefits: Look beyond medical. Compare 401(k) match, tool allowance, paid training, and paid time off.
  • Bonuses: Some shops pay sign-on or retention bonuses for certified welders.
Safety and Working Conditions
Ask to see the shop's OSHA 300 log or EMR (experience modification rate). A rate below 1.0 is better than average. Check ventilation, fume extraction, and whether fit testing for respirators is provided.
Union, Travel, and Advancement
Union offers often include a negotiated wage scale, pension, and credits through welding apprenticeship programs. Nonunion shops may offer faster advancement but less job security. Clarify travel percentage and whether per diem covers weekends. Ask about path from structural to pipe welding or CWI.
Negotiating from Strength
Use certifications , including a 4g welding certification , to anchor a higher rate. A 6G pipe certification or an AWS D1.1 qualification can justify $3 to $8 more per hour. If you have verifiable experience, ask for a tool allowance or guaranteed overtime minimum. Don't accept the first number if the offer includes high turnover risk or poor safety record.
