Submerged Arc Welding Explained: How SAW Delivers Deep, Clean Welds
Learn how the flux-covered arc works, where SAW excels, and how to choose equipment.
Submerged arc welding deposits more weld metal per hour than any manual arc process. A single wire under a blanket of granular flux can lay down pounds of weld metal in a fraction of the time stick or MIG welding would require, so shipyards, pipe mills, and pressure-vessel shops build much of their production around it.
The process hides the arc entirely beneath flux, melts the wire and base metal deep into thick joints, and produces almost no spatter or visible arc flash. That buried arc also imposes a strict limit: SAW cannot weld overhead or vertical positions. For heavy plate and long straight seams in the flat or horizontal position, however, its deposition rate has no equal.
What Is Submerged Arc Welding (SAW)?
Submerged arc welding is a wire-fed process in which the arc burns beneath a blanket of granular flux. The name says it plainly: the arc is submerged. As the electrode wire feeds into the joint, flux pours ahead of and around it, completely covering the arc zone. Because that blanket smothers the arc, there is no visible arc light, no spatter thrown across the shop, and very little smoke or ultraviolet radiation reaching the operator. From a few feet away, all you see is a moving wire and a mound of flux.
The Dual Role of the Flux
The granular flux does two jobs at once. First, as it melts, it forms a gaseous and molten shield that protects the weld pool from atmospheric oxygen and nitrogen, no separate shielding gas required. Second, the melted flux cools into a solid slag layer over the finished bead. That slag slows cooling, shapes the bead profile, and can add alloying elements to the deposit depending on the flux chemistry. Unmelted flux is recovered and reused, while the slag peels or chips away once the weld cools.
Bead Characteristics and Automation
SAW is prized for deep penetration and high deposition rates. The concentrated, insulated arc drives heat into thick material, so a single pass can fuse plate that would take multiple passes with other welding processes. Deposition rates far exceed manual stick welding or MIG welding, which is why fabricators reach for SAW on heavy steel.
One trade-off shapes everything about how SAW is used: because the operator cannot see the arc, the process is almost always mechanized rather than hand-held. The torch rides on a tractor, boom, or fixed column while the workpiece or head moves at a controlled travel speed. This makes SAW ideal for long, repeatable welds in the flat or horizontal position, but poorly suited to overhead or position work.
How the SAW Process Works: Arc, Flux, Slag, and Solidification
The arc in submerged arc welding burns completely hidden beneath a mound of granular flux, which is why the process produces no visible arc flash and almost no spatter. That buried arc is the defining feature of SAW, and understanding the sequence explains both its high deposition rates and its clean, protected weld metal.
Arc Ignition Under the Flux
The process begins as a continuously fed bare wire electrode advances toward the workpiece, similar to the wire feed used in MIG welding. A granular flux is laid down ahead of the arc through a hopper and delivery tube, blanketing the joint. When the wire touches the plate and current flows, an arc ignites beneath that flux layer. Because the covering is thick and dense, none of the ultraviolet or intense visible light escapes, and the operator sees only the flux pile and a faint glow.
Flux Melting, Gas Shield, and Slag Formation
The arc's heat melts the surrounding flux. Part of it vaporizes to create a shielding gas atmosphere and a protective cavity around the arc, while the rest fuses into a liquid slag. This molten slag floats on top of the weld pool, insulating it from atmospheric oxygen and nitrogen. Unmelted flux beyond the arc zone stays granular and can be recovered and reused. The combination of gas cavity and liquid slag keeps the pool fully protected without any external shielding gas cylinder, unlike TIG welding.
Pool Solidification and Slag Removal
As the arc travels forward, the molten weld pool cools and solidifies under the slag blanket. The slag itself freezes into a glassy crust over the finished bead, continuing to shield the metal as it drops through the sensitive cooling range. Once the weld cools, the hardened slag is removed. With many basic and agglomerated fluxes, the slag is self-peeling, lifting off cleanly in a single sheet; other formulations require light chipping. Proper slag detachability is a real consideration when selecting a flux for a given joint and travel speed.
SAW Parameter Ranges and Heat Input for Carbon Steel, Stainless, and Low-Alloy Steel
Dialing in SAW parameters is a balancing act between deposition rate and heat input: push voltage and amperage too hard and you risk excessive dilution, coarse grain structure in the heat-affected zone, and toughness loss; run too cold and you get lack of fusion or slag entrapment. The right window depends on base metal chemistry, plate thickness, and the code you are welding to. AWS D1.1 (structural steel) and AWS D1.6 (stainless) both require qualified procedures with heat input tracked when notch toughness or corrosion performance matters.
Carbon and Low-Alloy Steel
For carbon and low-alloy structural steel, published Lincoln Electric procedure data gives a useful anchor. A single-wire SAW fillet run with a 5/32 in electrode at 31 V, 525 A, and 18 in/min produces roughly 54 kJ/in of heat input.4 That is a hot, high-deposition setting appropriate for thicker plate (roughly 3/4 in and up) where slower cooling is tolerable. For thinner plate or notch-tough low-alloy grades, Bavaria Schweisstechnik procedure sheets show a 4 mm electrode running around 30 V, 580 A, and 55 cm/min (about 22 in/min), landing near 18 to 21 kJ/in.3 That lower band is typical when a Charpy requirement forces the fabricator to cap heat input to preserve HAZ toughness.
As a rough working range for carbon and low-alloy steel between 1/4 in and 2 in plate: 28 to 34 V, 400 to 800 A, and 15 to 30 in/min, with heat input typically held between 15 and 60 kJ/in depending on the code and toughness class.
Austenitic Stainless Steel
Stainless SAW runs cooler and faster than carbon steel to protect the alloy content. Lincoln Electric's data for 308/308L and 316/316L wire in 5/64 in diameter lists 24 to 30 V, 190 to 500 A, and travel speeds from 80 to 240 in/min in strip or high-speed cladding modes.12 For conventional joint welding rather than overlay, most shops stay in the lower amperage half of that range and cap heat input around 40 to 50 kJ/in to limit sensitization, ferrite loss, and hot cracking in fully austenitic grades.
Verifying Against Your WPS
Treat these numbers as starting points, not a substitute for a qualified WPS. Always verify against your consumable manufacturer's procedure sheet, the governing code, and PQR test results before production welding.
Flux Types, Electrodes, and Consumable Selection for SAW
What flux and wire combination should you use for carbon steel, stainless, or low-alloy SAW work? AWS SAW classifications describe the flux-electrode combination, not the wire or flux alone.
Flux families: fused, bonded, and agglomerated
  • Fused flux: Melted minerals form a chemically uniform, generally nonhygroscopic glass. Chemistry is fixed after melting, so selective alloying is harder. Common in structural carbon steel, pressure vessels, shipbuilding, and pipe.
  • Bonded flux: Ground minerals and a binder are cured at low temperature. This allows flexible alloying and good uniformity, but moisture pickup depends on the formulation. Used for low-hydrogen structural work, pressure vessels, low-alloy steel, and high-strength steel.
  • Agglomerated flux: Granulated or binder-based flux available for carbon steel, low-alloy steel, stainless steel, duplex stainless steel, and nickel alloys.
Fused flux is generally the least moisture-sensitive option. Bonded and agglomerated fluxes may require controlled storage or rebaking, and rough handling can change particle size.
AWS classification: read the combination, not just the wire
An A5.17 designation such as F7A5-EM12K-H4 reports the welded deposit from a flux-electrode test. F is flux, 7 indicates the 70 ksi minimum tensile strength class, A means as-welded, and EM12K identifies the electrode. H4 caps diffusible hydrogen at 4 mL/100g.1 A P in that position means postweld heat-treated testing, as in F6P4-EM12K2 or F9P4-EB3-B3-H4. F8P8-ECNi5-Ni5-H4 is an example for high-strength quenched-and-tempered steels and API 5L X70 pipe steels.3
A5.17 covers carbon-steel electrodes and fluxes. A5.23 covers low-alloy and high-manganese steel combinations. Do not choose A5.17 for low-alloy work just because the wire diameter fits. A5.9/A5.9M:2022 covers bare stainless electrodes and rods4; A5.39 covers stainless and nickel-alloy SAW flux/electrode combinations. Check the current specification before final selection.
Electrode grades and common material matches
Solid wire is the workhorse; metal-cored wire can improve deposition rate or bead profile but must be matched to a compatible flux. Select by deposit strength, toughness, corrosion resistance, ferrite balance, service temperature, and required PWHT, not by diameter or travel speed alone.
  • Carbon steel: EM12K, EM13K, and EH14 are common.1 Pair them with the F7A class meeting required impact and hydrogen limits.
  • Low-alloy steel: Use A5.23 combinations such as EB3-B3 for chromium-molybdenum service or ECNi5-Ni5 for high-strength quenched-and-tempered applications.3 P designators apply when postweld heat treated.
  • Stainless steel and nickel alloys: ER308L suits 304/304L, ER316L suits 316/316L, ER309L suits stainless-to-carbon or stainless-to-low-alloy joints, ER347 suits 321/347 stabilized grades, ER2209 suits 2205 duplex, and ERNiCrMo-3 suits nickel alloys and dissimilar joints.4 The L in 308L/316L indicates low carbon for sensitization control.
SAW Equipment: Power Sources, Wire Feeders, Flux Hoppers, and Travel Mechanisms
As with MIG Welders and Power Supplies, constant-current and constant-voltage power sources solve different problems on the SAW line. Constant-voltage machines are the workhorse for single-wire and multiwire setups because they self-regulate arc length as wire feed speed changes, which suits the continuous, high-deposition nature of the process. Constant-current sources still show up on heavier single-pass work where an operator or automated system actively adjusts voltage. Either way, SAW power sources are built for sustained duty cycles, with common ranges running from around 400 to 1,500 amps depending on wire diameter, joint thickness, and whether the setup runs single or multiple arcs.
Wire and Flux Delivery
The wire feeder pushes solid or cored electrode through a contact tip into the joint at a fixed speed matched to the power source's output. Ahead of or alongside the wire, a flux hopper gravity-feeds granular flux through a nozzle, burying the arc completely before it strikes. Recovery systems vacuum unfused flux back into the hopper for reuse, which cuts consumable cost significantly on long production runs.
Mechanized Travel Options
Unlike MIG welding, SAW is rarely run freehand because the buried arc gives the operator no visual reference. Instead, travel is mechanized through one of several carriages:
  • Tractor units: self-propelled carriages that ride directly on the plate or a track, common in shipyard panel lines.
  • Boom and column systems: fixed overhead arms that travel along a rail, typical in pipe mills and vessel fabrication.
  • Gantries: bridge-mounted heads spanning wide plate, used for structural and heavy fabrication shops.
  • Multi-head setups: two or more torches mounted on a single carriage for tandem or multiwire deposition.
Automation Level
Most SAW installations run semi-automatic to fully automatic, rarely manual. Semi-automatic setups still need an operator to guide the carriage and monitor the puddle, while fully automatic lines integrate seam tracking, programmable travel speed, and multiple arcs for unattended production on repetitive joints like pipe seams and pressure vessel shells.
Multiwire SAW: Twin, Tandem, and Multiwire Deposition Rates
Deposition rates for submerged arc welding rise as wire count and amperage increase. The table below compares typical single wire, twin wire, tandem wire, multiwire, and tandem twin wire configurations using manufacturer and AWS handbook values. Actual results vary with joint design, travel speed, flux type, and power source.
ConfigurationTypical Deposition Rate (lb/hr)Key Advantage
Single-wire SAW14.3 lb/hr (6.5 kg/h)N/A
Twin-wire SAW41.2 lb/hr (18.7 kg/h)Increases deposition rates by 20 to 30 percent versus single-wire DC SAW without significantly increasing heat input.
Tandem-wire SAW51.1 lb/hr (23.2 kg/h)Achieves deposition rates in the 40 to 60 lb/hr range with a combined welding current of 1,400 A.
Multiwire SAWUp to 83.8 lb/hr (38 kg/h)N/A
Tandem twin-wire SAW77 lb/hr (35 kg/h)N/A
Common SAW Defects and How to Prevent Them
Defect prevention in submerged arc welding starts with controlling contamination, heat input, and flux conditions. The table below lists the most common SAW defects, their root causes, and practical corrective actions using AWS D1.1 acceptance criteria where structural code requirements apply.
DefectRoot CausePrevention
PorosityGas is trapped in the solidifying weld pool because of surface contaminants such as rust or grease, inadequate shielding, or insufficient deoxidants in the weld metal.Remove rust, oil, primer, and other contamination by brushing, grinding, degreasing, or preheating as appropriate. Dry or re-dry wet flux, preheat wet plate, and increase flux-bed height when the flux layer is too thin.
Slag inclusionSlag becomes trapped because of contaminated joints, inadequate cleaning between passes, or unsuitable flux conditions or flux coverage.Clean the joint and remove all slag between passes. Maintain appropriate flux coverage and use properly conditioned flux. Remove defective weld metal and re-weld when required by the welding procedure and the applicable code, such as AWS D1.1.
Solidification crackingCracking occurs when shrinkage strains open spaces between solidifying weld-metal grains and the available liquid weld metal cannot feed those spaces. High strain, restricted liquid feeding, and susceptible weld-metal composition increase the risk.Use weld metal with low carbon, sulfur, and phosphorus. Select wire with higher manganese when parent-metal impurities are elevated. Minimize dilution and ensure a favorable weld-bead profile. High-silica manganese and calcium-silicate fluxes can help keep weld-metal carbon low when compatible with the procedure.
UndercutUndercut is associated with excessive current or travel speed and an incorrect arc length or welding condition that prevents adequate filling of the weld toes.Reduce travel speed and/or welding current and maintain the correct arc length. Verify the welding procedure parameters and electrode positioning before continuing production.
Lack of fusionThe weld metal does not bond to the base plate because of low heat input, poor joint preparation, or an incorrect electrode angle.Increase amperage or voltage within the qualified procedure range. Correct or re-cut the joint preparation. Realign the electrode and inspect fit-up including gap, bevel angle, and surface condition before welding.
Because the arc burns entirely beneath a blanket of granular flux, SAW produces notably less visible smoke than open-arc methods. Emission-rate data referenced by welding safety literature places SAW under 1 mg/s, versus roughly 2 to 8 mg/s for shielded metal arc welding, and the flux also shields workers from most arc glare.
Advantages and Disadvantages of Submerged Arc Welding
Why do fabricators reach for SAW instead of just running a bigger MIG gun? The answer comes down to deposition rate and penetration, but the process has real limits that decide whether it belongs on your job.
Where SAW Wins
Because the arc burns beneath a blanket of granular flux instead of open air, current densities can run far higher than open-arc processes without spatter or arc glare. That translates into deposition rates several times higher than stick or MIG welding on comparable joints, which is why pipe mills and shipyards depend on it for long, straight, or rotated seams. Penetration is deep and consistent, letting engineers design fewer passes and, in many cases, thinner joint preparation. Because the flux shields the puddle completely, the finished bead is smooth and consistent, and the enclosed arc produces minimal visible fume and radiation compared to open-arc welding, a real benefit for operator comfort during long production runs.
Where SAW Falls Short
The biggest constraint is position. SAW relies on gravity to hold molten flux and puddle in place, so it only works flat or in horizontal-fillet orientations. Vertical, overhead, and most out-of-position work is off the table, which rules it out for field erection and repair jobs. Slag removal adds a step to every pass, and on multi-layer welds that means chipping and grinding time that a semi-automatic process would not require. Equipment cost is another factor. Tractors, wire feeders, flux recovery systems, and flux itself represent a bigger upfront and per-hour investment than a wire-feed MIG welding equipment setup, and flux handling (storage, drying, recycling contaminated flux) adds housekeeping that shops running FCAW or SMAW do not deal with.
Matching the Process to the Job
SAW earns its keep on long, flat or circumferential welds in thick plate or pipe, the kind of high-volume, repeatable seams found in pressure vessels, structural girders, and pipeline mills. If the joint can be positioned flat and the run is long enough to justify setup time, SAW usually outproduces every alternative. But for short welds, out-of-position work, field repair, or low-volume fabrication, the setup and slag-removal overhead outweigh the deposition advantage, and MIG, FCAW Flux Cored Arc Welding, or stick welding remain the more practical choice.
SAW vs. MIG, FCAW, and SMAW: Which Process Should You Choose?
Process choice usually hinges on where the weld is made and how many pounds of metal must be deposited per hour. In a controlled shop with heavy plate, SAW offers the highest production rates; in the field, stick and flux-cored often win on portability and access even at lower deposition.
FactorSAWMIG (GMAW)FCAWSMAW (Stick)
Typical deposition rateUp to 40 lb/hr with a single wire; over 100 lb/hr with tandem or multiwire setups2 to 5 lb/hr in short-circuit transfer; 5 to 12 lb/hr in spray transfer8 to 25 lb/hr1.5 to 3 lb/hr
Equipment and operator skillMechanized, fixed, linear welds; limited by joint configuration and impractical to fully automateMedium operator skillLow to medium operator skillSimplest equipment; high operator skill
Deposition efficiency or consumable use0.8 to 1.2 lb consumable per lb deposited; efficiency not reported in available data93 to 95%75 to 90%63 to 72%
Cost per pound of weld depositedConsumable use: 0.8 to 1.2 lb per lb deposited; dollar cost not reported$0.80 to $1.40 per lb for ER70S-6 wire$1.20 to $2.20 per lb$0.40 to $0.80 per lb for E7018 at 65 to 70% efficiency
Best applicationsHeavy plate and shop production on fixed, mechanized, linear weldsThin sheet to heavy plate; carbon steel, stainless steel, aluminum, and copperConstruction, shipbuilding, railcars, bridges, pressure vessels, mobile equipment, and overlay weldingStructural and maintenance work, medium and heavy sections, and field welding; all positions possible depending on electrode
One commercial market estimate for 2025 put shipbuilding at roughly 31 percent of global submerged arc welding flux demand, the largest single application tracked. Treat the figure as a market projection rather than audited production data, but it reflects how heavily yards lean on SAW for long, straight hull and deck seams.
Applications, Safety, and Industry Standards for SAW
Heavy fabrication shops keep leaning on submerged arc welding precisely because the process hides its arc, but that same trait creates safety questions that MIG welding or stick welding don't raise in the same way. Pressure vessel and boiler manufacturers, pipe mills, wind-turbine tower fabricators, shipyards, and structural steel shops all rely on SAW for long, thick-section welds where deposition rate and consistency matter more than portability.
Where SAW Shows Up on the Shop Floor
The common thread across these settings is high-volume, repetitive welding on thick plate or pipe: longitudinal and circumferential seams on pipe mill product, girth welds on pressure vessels, panel and seam welds in shipbuilding, and tower sections for wind energy. Mechanized and automated SAW setups dominate these environments because the flux blanket and buried arc suit long, straight, or rotated joints far better than manual out-of-position work.
Hazards Unique to a Covered Arc
Because the arc burns beneath a layer of granular flux, operators lose direct visual reference to the weld pool, which shifts risk toward mechanized travel controls, unexpected carriage movement, and nip points on wire feed and travel mechanisms6 rather than arc flash exposure alone. Flux dust handling, hot slag removal, and fume that escapes at high current or during starts and stops remain real hazards even though the arc itself is shielded. OSHA notably excludes SAW from its arc-welding helmet and hand-shield requirement under 1910.2521, but that exclusion doesn't erase eye and face risk. ANSI Z49.1, a consensus Welder Safety standard rather than an enforceable regulation, still calls for goggles, a helmet, or a faceshield over spectacles5.
Standards That Govern SAW Work
SAW safety draws from several OSHA sources depending on the setting: general industry work falls under 1910.252 and 1910.2541, construction under 1926.3532, and shipyard work under 1915 Subpart D3. Mechanized equipment guarding falls under 1910.2121, and lockout/tagout procedures under 1910.1471 apply whenever maintenance or clearing jams interrupts automated travel. On the qualification side, ASME Section IX (2025 edition) governs how welding procedures and welders are qualified, but it's a qualification code, not a safety program. It won't tell a shop how to ventilate, control flux dust, or guard a tractor.
Practical Safety Steps for Operators
  • Ventilation: Maintain general ventilation at the 2,000 cfm minimum specified under 1910.2521 where applicable, with local exhaust positioned so it captures fume without disturbing the flux blanket.
  • Slag and flux handling: Use a designated slag-removal area, hot-rated tools and containers7, and enclosed or sealed flux-recovery systems to limit dust exposure8.
  • Fire prevention: Clear combustibles within 35 feet where practical6, or install guards to confine sparks and hot slag.
  • PPE: Safety glasses, welding goggles, flame-resistant clothing, heat-resistant gloves, and safety footwear9 per 1910 Subpart I10.
  • Machine safety: Lock out mechanized travel and wire-feed equipment before servicing, and stay clear of nip points during operation6.
