The shift toward aluminum-intensive bodies and advanced high-strength steels has forced automakers to rewrite weld schedules that stayed stable for decades, a development covered in the Introduction to Welding. Resistance spot welding still carries the load: a single body-in-white can hold 3,000 to 6,000 spot welds, each formed in a fraction of a second.
Resistance welding is a family of processes, spot, seam, projection, and butt, that generate heat from the electrical resistance at the joint interface while electrode force holds the parts together. No filler metal, no shielding gas, no arc (unlike MIG welding).
The practical tension sits in the parameters. Current, weld time, and electrode force interact tightly, and a schedule tuned for 1 mm mild steel will produce expulsion or a cold joint on coated or high-strength sheet.
What Is Spot Welding and Resistance Welding?
A modern automotive body-in-white can contain 3,000 to 6,000 spot welds, making spot welding one of the most common welding processes in high-volume sheet metal manufacturing. But before you choose a process, it helps to understand exactly where spot welding sits in the resistance welding family.
Spot Welding Is a Resistance Welding Process
Spot welding is not a separate process from resistance welding; it is the most widely used type. Resistance welding includes spot, seam, projection, and butt welding. All of them rely on the same core idea: pass a high electrical current through the workpieces, use the resistance at the joint to generate heat, and apply pressure to form a solid-state or molten bond. In spot welding, the current is concentrated at a small, circular contact area between two electrodes, producing a single weld nugget at that spot.
How the Weld Forms
The basic principle is straightforward. Two or more overlapping sheets are clamped between copper alloy electrodes. When current flows, the highest electrical resistance is at the interface between the sheets. That resistance heats the metal locally until it melts. The electrodes continue to apply force while the current shuts off, allowing the molten metal to solidify under pressure. The result is a small, lens-shaped nugget that joins the sheets without any added filler metal.
How It Differs from Arc Welding
Compared with arc welding processes such as MIG welding, spot welding has a different operating profile: - Filler metal: None is used; the base sheets fuse directly. - Shielding gas: Not required, because the joint is enclosed between electrodes. - Open arc: There is no exposed arc, so the process is quieter, produces little spatter, and needs less fume extraction.
How the Resistance Spot Welding Process Works
Resistance spot welding fuses two or more overlapping sheets by clamping them between copper alloy electrodes and passing a high current through the joint for a brief, controlled interval. The heat generated at the sheet-to-sheet interface melts a small volume of metal, forming a lens-shaped nugget that solidifies under pressure. The cycle is short, repeatable, and easily automated, which is why it dominates high-volume sheet metal production.
The Four Stages of the Weld Cycle
Every spot weld follows the same sequence, typically measured in cycles of line frequency (1 cycle = 1/60 second on a 60 Hz supply):
- Squeeze time: The electrodes close and build up force before current flows. This seats the sheets, collapses surface irregularities, and stabilizes the electrical contact.
- Weld time: Current is passed through the stack. Resistive heating at the faying surface melts the base metal and grows the nugget.
- Hold time: Current stops but electrode force continues. The nugget solidifies under pressure, which refines the grain structure and suppresses cracking and porosity.
- Off time: Electrodes retract and the workpiece advances to the next location. In production, off time sets the cycle rate.
Force, Current, and Time Interaction
The three primary parameters are coupled. Higher electrode force lowers contact resistance and reduces heat generation, so it must be paired with higher current or longer weld time to reach the same nugget size. Too little force causes expulsion (molten metal ejected from the joint); too much force starves the weld of heat and produces a stuck, undersized nugget.
Contact Resistance and Heat Balance
Heat follows Joule's law: Q = I²Rt. The critical R is the contact resistance at the sheet-to-sheet interface, which should exceed the electrode-to-sheet resistance so that peak heating occurs where the nugget needs to form, not at the electrode face. Clean, oxide-free surfaces, matched electrode geometry, and balanced sheet thicknesses keep the heat centered in the joint and protect electrode life.
A spot weld nugget forms astonishingly fast. Research on coated automotive sheet steel shows the molten nugget develops in roughly 35 to 50 milliseconds, while advanced high-strength steels may need around 0.18 seconds for nugget initiation. That entire fused joint happens in a fraction of a second.
Resistance Welding Process Family: Spot, Seam, Projection, and Butt Welding
Resistance welding includes several closely related processes that join metal using current and pressure, with no filler material. The table below summarizes the four main types, including how each process works, typical equipment, sheet thickness ranges, and common industrial applications.
| Process | Mechanics | Equipment Type | Typical Sheet Thickness | Typical Applications |
| Resistance spot welding | Passes current through overlapping workpieces while electrode force is applied, forming discrete weld nuggets at the interface. | Opposed electrode tooling that applies force and current at individual weld locations; production equipment is commonly automated. | 0.4 mm to 3 mm (maximum single sheet) | High-speed production of sheet-metal assemblies. |
| Resistance seam welding | Uses overlapping welds along a joint, commonly with rotating wheel electrodes, to create a continuous or intermittently welded seam; lap seam welding can produce continuous leak-tight joints. | Wheel-electrode seam-welding equipment that rolls along a straight joint while applying force and current. | 0.4 mm to 3 mm (maximum single sheet) | Leak-tight sheet-metal joints, including automotive gas tanks. |
| Projection welding | Concentrates current and balances heat at deliberately formed projections, allowing parts to reach a more uniform temperature across the interface; multiple welds can be made simultaneously. | Projection-welding equipment using welding dies or electrodes aligned with formed projections; multiple-weld tooling can make several welds simultaneously and requires precise alignment. | 0.4 mm to 3 mm (maximum single sheet for embossed resistance projection) | Thicker-part assemblies, joints with significant size or electrical-conductivity differences, and applications requiring closely spaced or simultaneously produced welds; can replace arc-welding processes such as GMAW. |
| Butt welding | Joins members end-to-end rather than by overlapping sheets; resistance butt variants include flash and upset welding, in which current and end pressure heat and consolidate the abutting interfaces. | Butt-welding machines with opposed workholding jaws or dies to align and clamp the ends, plus a resistance power supply and axial force system; AWS resistance-welding practice covers flash and upset welding. | N/A | End-to-end joining of material sections, including resistance-welded seams and components where the length of the seam or joint is a consideration. |
Spot Welding Equipment, Electrodes, and Maintenance
Fixed pedestal welders anchor high-volume, repeatable work on a shop floor, while portable transformer guns bring the current to the part, letting a robot or an operator chase weld locations on a car body. That basic split (part comes to the machine vs machine goes to the part) drives most equipment choices in a resistance spot welding cell.
Machine Types
- Pedestal welders: Stationary single-phase or inverter machines with fixed lower and upper arms, used for bench sheet metal work and small assemblies.
- Portable guns: C-type and X-type transformer guns suspended on balancers, common in body-in-white repair and manual production lines.
- Robotic guns: Servo-driven X and C guns on articulated robots, the standard for automotive body-in-white where thousands of welds must land in cycle time.
- Press welders: Larger stationary machines built for projection welding and heavier assemblies where multiple welds fire simultaneously through shaped electrodes.
Electrode Materials
Electrodes are copper alloys chosen to balance conductivity, hardness, and wear resistance.2 The RWMA class system is the working reference:1
- Class 1 (Zirconium Copper, C15000): Best for aluminum, magnesium, brass, and bronzes, where high conductivity matters more than hardness.
- Class 2 (Chromium Copper C18200, Chromium-Zirconium Copper C18150): The general-purpose choice for steel and stainless steel production work. CuCrZr, CuZr, and Cu-Al2O3 composite caps are commonly used on galvanized sheet.
- Class 3 (Cobalt-Beryllium Copper, C17500): Higher hardness for stainless steel, Nichrome, Inconel, and Monel.
- Refractory tips (Molybdenum, Tungsten, WCu): Used when welding pure copper or similar high-conductivity alloys where standard copper tips would stick.3
Cooling and Tip Dressing
Electrodes soften and mushroom without adequate internal cooling. TWI recommends a minimum water flow of about 4 l/min for thin, uncoated steel and 6 l/min or more for coated or thicker steels. Inlet water should sit at or below 20 °C and outlet at or below 30 °C. For effective heat transfer, the electrode body diameter should be roughly 2.5 to 3 times the tip face diameter, and the internal cooling tube should be cut at 45° and aimed at the inside face of the tip.
Tip dressing frequency is not a fixed number. Practical shops either dress lightly and often to hold tip geometry, or let the tip wear and dress back to the original profile, sometimes paired with current stepping to compensate for wear between dressings. Actual intervals depend on coating type, sheet thickness, and electrode material.
How Much Do Welders Earn? Median Wage Snapshot
Spot Welding Parameters: Current, Time, and Force by Material and Thickness
The reference settings below are typical for resistance spot welding of mild steel and galvanized steel sheet of equal thickness stacked in pairs. Stainless steel and aluminum require different current, time, and force schedules and are not included in this table. Always verify parameters with your machine manufacturer or a current welding procedure specification.
| Material | Thickness (mm) | Welding Current (kA) | Weld Time (cycles) | Electrode Force (kN) |
| Mild steel | 0.63 + 0.63 | 8.500 | 6 | 2.00 |
| Mild steel | 0.71 + 0.71 | 8.750 | 7 | 2.12 |
| Mild steel | 0.80 + 0.80 | 9.000 | 8 | 2.24 |
| Mild steel | 0.90 + 0.90 | 9.250 | 9 | 2.36 |
| Mild steel | 1.00 + 1.00 | 9.500 | 10 | 2.50 |
| Mild steel | 1.12 + 1.12 | 9.750 | 11 | 2.80 |
| Mild steel | 1.25 + 1.25 | 10.000 | 13 | 3.15 |
| Mild steel | 1.40 + 1.40 | 10.300 | 14 | 3.55 |
| Mild steel | 1.50 + 1.50 | 10.450 | 15 | 3.65 |
| Mild steel | 1.60 + 1.60 | 10.600 | 16 | 4.00 |
| Mild steel | 1.80 + 1.80 | 10.900 | 18 | 4.50 |
| Mild steel | 3.00 + 3.00 | 12.350 | 4x9+2 | 6.15 |
| Galvanized steel | 1.0 + 1.0 | 12 | 16 | 3.11 |
| Bare steel | 1.0 + 1.0 | 8 | 10 | N/A |
Aluminum's high electrical and thermal conductivity means it can demand roughly two to three times the current and electrode force needed to spot weld steel of similar thickness, with some setups running 27 to 37 kA and up to 8 kN of force. AWS recommended practices note these elevated requirements, so equipment sized for steel often can't handle aluminum without upgrades.
Common Spot Welding Defects and Remedies
Resistance spot welding defects usually point to a mismatch in current, time, force, electrode condition, or material fit-up. The table below summarizes six common defects, their primary causes, and typical corrective actions drawn from AWS and ISO guidance plus everyday shop practice.
| Defect | Primary Cause(s) | Remedy |
| Expulsion | Excessive weld current or weld time; insufficient electrode force; poor fit-up; dirty or scaled material; inadequate cooling; incorrect electrode alloy, face diameter, alignment, or tooling setup. | Increase electrode pressure; reduce weld time; realign or dress electrode tips; clean or dress tips when base material sticks; verify material thickness and machine capacity. |
| Weak nugget | Insufficient current or weld time; excessive electrode pressure; electrode wear; poor electrode condition; inadequate contact or surface contamination; shunting; poor fit-up. | Increase weld time when appropriate; use a multi-pulse schedule or post-heating; increase electrode-tip diameter or change electrode type; increase minimum weld size. |
| Sticking | Insufficient current or weld time combined with excessive pressure; electrode wear; contaminated or coated surfaces; inadequate electrode cooling. | Maintain and correctly select electrodes; inspect and correct electrode alloy, face diameter, cooling, alignment, and tooling setup; correct weld schedule for current, time, and force balance. |
| Excessive indentation | Excessive tong pressure; weld time too long; misalignment of electrode tips. | Reduce tong pressure and weld time; realign electrode tips; dress tips to proper diameter. |
| Cracking | Excessive weld current; insufficient electrode force; electrode misalignment; insufficient electrode cooling; short hold time; short squeeze time; improper heat balance. | Prevent excessive splash by correcting current and electrode force; ensure adequate force and control nugget heat balance; improve cooling and squeeze/hold timing. |
| Electrode wear | High temperature, high pressure, and alloying of copper with aluminum; expulsion; inadequate cooling; incorrect electrode material, size, shape, or maintenance. | Inspect electrode material, size, shape, and condition; review and improve resurfacing or dressing procedure; maintain adequate cooling and electrode alignment. |
A modern car body typically contains 3,000 to 6,000 resistance spot welds holding its sheet metal panels together, according to automotive manufacturing publications. MINI's Plant Oxford reports roughly 6,000 spot welds on every vehicle it builds, each one forming in a fraction of a second before the body even reaches the paint shop.
Spot Welding Inspection and Testing Methods
How do you prove a spot weld is good when the nugget is hidden between two sheets of steel? You either use destructive weld testing and break the joint apart to look at it, or use a method that reads through the metal. Both approaches have a place, and automotive quality systems and welder certifications lean on a mix of the two.
Destructive tests
These are the workhorses of weld qualification because they expose the nugget itself. AWS D8.7M, Recommended Practices for Automotive Weld Quality, covers the core methods.1 AWS D8.1M-2021, Specification for Automotive Weld Quality Resistance Spot Welding, carries destructive acceptance criteria as well.2
- Peel test: The sheets are pulled apart so the weld either tears a plug from one sheet or fails at the interface. Fast, shop-floor friendly, used for setup and periodic sampling.
- Chisel test: A wedge is driven between the sheets to open the joint and reveal fracture mode. Covered in both D8.7M and D8.1M-2021.12
- Tensile-shear test: Loads the joint in the plane of the sheets until failure, giving a measurable load number.
- Cross-tension test: Loads perpendicular to the sheet plane, a peel-type opening rather than in-plane shear. Useful for judging ductility on higher-strength steels.
- Cross-section (macro-etch): The weld is cut, polished, and etched so nugget diameter and penetration can be measured directly.
Non-destructive tests
Visual inspection comes first: electrode indentation depth, surface expulsion, sheet separation, edge distance. D8.1M-2021 sets visual criteria for production spot welds.2 Ultrasonic testing is the main in-service method for reading nugget size without cutting the part, and AWS B1.10M/B1.10:2016, Guide for the Nondestructive Examination of Welds, describes how UT is applied.3 Radiographic testing finds porosity, slag, incomplete fusion, and penetration-related discontinuities, though it is used far less on sheet spot welds than on structural joints.4
What counts as acceptable
Acceptance is not simply "a nugget formed." It rests on nugget size, fracture mode, and load capacity as defined by the governing standard for the material and thickness being joined.2 Shops often quote a minimum nugget diameter tied to the square root of sheet thickness, but the actual limit comes from the applicable AWS or ISO document and the qualified procedure, not a universal number. Because RT and UT judge discontinuities rather than certifying nugget diameter, they supplement destructive testing during production rather than replace it when minimum nugget size must be proven.3
Automotive and Sheet Metal Applications of Spot Welding
Resistance spot welding is the backbone of automotive body-in-white (BIW) assembly, joining roof rails, floor pans, door rings, and reinforcements into a rigid unibody. It also dominates sheet metal work in appliance cabinets, HVAC enclosures, and steel furniture, where thin gauges, high throughput, and consistent joint geometry favor RSW over MIG welding and other arc processes. The governing standards are AWS D8.1M:2021 for automotive steel1 and AWS D8.2M:2026 for automotive aluminum2, with ISO 14373:2024 covering coated low-carbon steel.
Coated Steels, AHSS, and Aluminum
Modern BIW is a mixed-material puzzle. Galvanized and galvannealed coatings shift current flow, accelerate electrode wear, and narrow the welding lobe, so schedules that work on bare steel often expel or undersize on coated stock. Advanced and ultra-high-strength steels (AHSS and UHSS) push the window narrower still. SSAB's welding handbook for AHSS and UHSS covers resistance spot, laser, and arc processes, including TIG Welding, and emphasizes tighter control of current, force, and time than mild steel requires.5
OEM repair guidance can be even more specific than the general standards. Honda, for example, requires removing the 10-micron aluminum coating from the weld zone on 1,500 MPa hot-stamp steel or the joint may fail, and it rejects AUTO mode on that grade in favor of model-specific manual settings.4 Aluminum BIW panels, welded per AWS D8.2M:20262, demand different electrodes, higher current, and more aggressive electrode dressing than steel.
Stack-Up Design and Shunting
ISO 14373:2024 sets practical limits for coated low-carbon steel: sheets from 0.4 to 3 mm, two or three sheets per stack, total thickness no more than 9 mm, and a thickness ratio no greater than 3:1. Unbalanced stacks concentrate heat in the thinner sheet and raise the risk of expulsion, imprint, and undersized nuggets on the far side. Schedules should be qualified on the actual stack-up, not on nominal grade alone.
Shunting is the other design trap. When a new weld sits too close to existing nuggets or a parallel metal path, current diverts through those paths, cutting effective current at the joint and shrinking the nugget. Weld spacing rules in body engineering exist for this reason.
Robotic Versus Manual Systems
High-volume BIW lines run robotic RSW guns with cycle times of roughly 0.8 to 2.5 seconds per joint on 0.6 to 3.0 mm steel.3 Typical defect risks include undersized nuggets, expulsion, and surface indentation, all managed through adaptive controls and tip dressing. Manual and semi-manual pedestal or portable guns are the norm in collision repair, low-volume fabrication, and access-limited joints, where technicians follow OEM body repair manuals rather than generic schedules.
