Certified Welding Inspectors typically out-earn the $53,750 national median for welders, and the credential is increasingly treated as a hiring filter on structural, pipeline, and pressure-vessel work governed by AWS D1.1, API 1104, and ASME code.
The tension for most candidates is front-loaded: eligibility hinges on a mix of education and documented welding experience, the three-part AWS exam has a reputation for weeding out underprepared applicants, and total out-of-pocket cost with a seminar routinely clears $3,000 before a single inspection job is booked.
Across North America, CWI remains the default specification on postings for welding jobs, while CSWIP and ASNT credentials fill distinct niches in overseas contracts and nondestructive testing.
What Is a CWI and What Does a Welding Inspector Do?
The American Welding Society (AWS) issues the Certified Welding Inspector (CWI) credential, a certification that verifies an inspector's ability to evaluate welds against codes such as AWS D1.1 and API 1104. Unlike a welding certificate that proves hands-on skill, the CWI is a personnel qualification that demonstrates code knowledge, inspection technique, and professional judgment. In most contracts, the CWI is the person who decides whether a weld stays or gets repaired.
Daily Responsibilities of a CWI
A CWI's workday typically moves between the weld bay, the field, and the paperwork trail.
- Visually inspecting completed welds for cracks, porosity, undercut, incomplete fusion, and improper size or profile.
- Reviewing welding procedure specifications (WPS) and procedure qualification records (PQR) to confirm the welder is working within approved parameters.
- Checking base metal preparation, preheat, interpass temperature, and post-weld heat treatment where the code requires it.
- Verifying that welders hold current qualifications for the joint type and position being welded.
- Coordinating with nondestructive testing (NDT) technicians and reviewing ultrasonic or radiographic results when a visual indication requires further investigation.
- Writing inspection reports that document discontinuities, acceptance or rejection decisions, and corrective actions.
Why Employers Rely on the CWI Credential
Structural steel, pipeline, aerospace, pressure vessel, and bridge projects frequently list the CWI as the minimum qualification for inspection personnel. Contract specifications often require an AWS CWI to sign off on welds before the work can be accepted. That requirement exists because the CWI exam tests not just visual acuity but also the ability to locate and apply the right code provisions. Employers trust the credential because it is backed by documented experience and an exam that many candidates do not pass on the first attempt.
For a fuller picture of the career, including work environments and advancement, see the welding inspector career profile.
Welding Inspector Pay at a Glance
Nationally, welders, cutters, solderers, and brazers earn a median of $53,750 per year. Certified welding inspectors typically earn above this because inspection work requires additional code knowledge and certification.
CWI Eligibility: Education and Experience Requirements
AWS publishes an education and work experience matrix used to qualify candidates for the Certified Welding Inspector program. Higher education can offset part of the required welding-based experience, and options such as formal vocational training, military-approved high school equivalency, and documented teaching experience may also satisfy specific requirements. All work experience must be verifiable and directly related to welding inspection or quality functions.
| Education Level | Required Work Experience | Notes / Substitutions |
| High school diploma or GED | Minimum of 5 years welding-based work experience | Baseline route. Higher education may substitute for part of the work experience requirement. |
| Bachelor's degree in welding engineering or welding technology | Minimum of 1 year welding-based work experience | Four years maximum substitution. |
| Associate degree or higher in welding | Minimum of 2 years welding-based work experience | Three years maximum substitution. |
| Associate degree or higher in non-welding engineering technology, engineering, or physical science | Minimum of 2 years welding-based work experience | Three years maximum substitution. |
| Bachelor's degree or higher in non-welding engineering technology, engineering, or physical science | Minimum of 3 years welding-based work experience | Two years maximum substitution. |
| Two years post-high-school education in welding, engineering technology, engineering, or physical sciences | Minimum of 6 months experience in welding functions | May be used as an alternative with supporting documentation, such as transcripts or letters of reference specifying earned training credit hours. |
| High school graduate or state- or military-approved high-school-equivalency diploma (CAWI/AWI route) | Minimum of 2 years experience in an occupational function directly related to weldments fabricated to national or international standards and directly involved in an AWS B5.1-listed area | State- or military-approved high-school-equivalency diploma, such as a GED, satisfies the high-school education condition. |
| At least eighth-grade education | Minimum of 4 years work experience in welding functions defined under AWS B5.1 | N/A |
| Less than eighth-grade education | Minimum of 6 years experience in welding functions defined under AWS B5.1 | N/A |
| At least eighth-grade education plus one year vocational welding education and training | Minimum of 3 years experience in welding functions defined under AWS B5.1 | N/A |
The Three-Part CWI Exam: Fundamentals, Practical, and Code Book
The CWI exam asks you to prove three different skills at once: recall of welding fundamentals, hands-on inspection judgment, and the ability to locate correct requirements in a code book under time pressure. Passing each section separately is the practical reality.
Part A: Fundamentals
Part A is a closed-book multiple-choice exam with roughly 150 questions covering welding processes such as MIG welding, metallurgy, heat control, nondestructive examination, and safety. You need at least 72% to pass. Focus areas include base metal behavior, discontinuities, welding symbols, and qualification basics. This section rewards structured review of AWS Welding Inspection Technology materials.
Part B: Practical
Part B uses 46 questions to test whether you can evaluate a weld visually. You will measure and judge weld replicas and plastic models using standard inspection tools such as fillet weld gauges and calipers. Questions ask you to identify discontinuities, apply acceptance criteria, and choose the right tool. The pass mark is again 72%, and practice with actual gauges and sample defects tends to help more than rereading theory.
Part C: Code Book
Part C is the open-book portion. You select one code to be tested on: AWS D1.1 for structural steel, API 1104 for pipelines, or AWS D1.5 for bridges. The exam contains about 55 to 60 questions, and you must still score 72%. Because the book is open, the challenge becomes speed and navigation: knowing where to find a clause matters as much as understanding the rule. Candidates who highlight, tab, and index their code book consistently perform better.
All three parts must be passed within the attempt window and attempt limits set by AWS. If you pass two parts and fail one, you do not have to retake the entire exam. You schedule and retake only the part you failed, which reduces both study time and retest fees.
The test is delivered on computer at Prometric testing centers or at approved AWS seminar sites. Online at-home proctoring is not an option, so plan for in-person scheduling and bring approved code books, calculators, and identification.
CWI Exam Pass Rates, Retake Rules, and Scheduling
The CWI exam pass rate is the share of candidates who clear all three parts, and it is one of the most-searched numbers in this credential. The honest answer: AWS does not publish an official aggregate pass rate, so every figure you see comes from training providers reporting their own students or estimating industry-wide results. Treat these as rough context, not gospel.
What the Pass Rates Actually Look Like
Third-party estimates vary wildly because they measure different populations (prepped vs. unprepped, first-time vs. all attempts). Reported first-time rates range from 25-30% at Atlas API Training to around 90% at MadSkillsLLC, with figures near 50%4 and 60%5 in between. A useful part-by-part breakdown from Atlantis NDT estimates roughly 70% first-time pass on the fundamentals section, 50-55% on the hands-on practical, and 60-65% on the open-book code section. Passing two parts but failing one means no certification: you must clear all three, each at 72% or higher.
Retake Rules and Fees
If you fail a part, AWS generally requires a 14-day wait before retesting.1 Under 2026 fee copy, each retested part runs about $275, or roughly $595 for members and $810 for non-members to retake all three.2 For repeat attempts, AWS requires 16 hours of documented training for a one- or two-part retake, or 40 hours for a full three-part retake.2 You are capped at three retests within three years of your initial exam, and an incomplete exam counts as an attempt.2 Confirm current fees before paying, since published figures shift.
Can You Test Online, and How Scheduling Works
The CWI exam is in-person for 2026: there is no remote-proctored option. The fundamentals and code-book parts are computer-based at Prometric centers (450+ worldwide), while the practical part is administered at AWS seminar sites in the US or through AWS agents internationally.
After AWS approves your application, you receive a Confirmation Letter, then schedule through Prometric. The computer-based parts offer flexible dates subject to center availability, but the practical part is tied to the seminar calendar, with US registration due roughly six weeks ahead. Once you sit the practical, you generally have 60 days to complete the other two parts.3 A clean first-try path can wrap in weeks to a couple of months; missed deadlines or retakes extend it.
Your Path to CWI Certification
The Certified Welding Inspector route follows a fixed sequence, and skipping an early requirement can stall your exam date. Most candidates move from eligibility review to a scheduled exam in roughly three to six months. Code book choice is the fork in the road: it sets which practical test version and open-book code section you will face.
How to Prepare for the CWI Exam: Training Courses and Study Strategies
The main tradeoff in CWI prep is speed versus cost: a one-week bootcamp gets you exam-ready fast but runs into the thousands, while self-study with the right books can cost a few hundred and take months. Your budget, work schedule, and how confident you feel with welding codes should drive the choice.
Compare the Main Prep Routes
- AWS instructor-led seminars: The AWS 2-Week Online CWI Seminar and the 2-Week In-Person CWI Seminar are the flagship prep courses. The online seminar is priced at $2,245 for AWS members (seminar-only), with a seminar-plus-exam bundle at $3,070. The in-person 2-week version runs $2,875 seminar-only or $3,935 bundled. AWS also offers an 8-Week Online CWI Seminar that meets live in the evenings, priced the same as the 2-week online option, and a 3-day Part B Practical Seminar ($1,135) focused on the hands-on portion. Non-member pricing is higher, and a refundable deposit typically applies to the exam bundle.
- AWS self-paced pre-seminar: About 80 hours of online coursework at $1,030 for members. Good as a warmup before a live seminar, or as standalone review if you already have strong code experience.
- Third-party online prep: SI Certs offers an 80-hour online CWI course covering Parts A, B, and C for $1,197, with individual parts available separately. Online prep from various providers currently ranges roughly $449 to $2,510 depending on scope and format.1
- Community college prep: Some community colleges run 8 to 16-week CWI prep courses through their welding or continuing education departments. Tuition varies widely by state and residency; check your local school directly. Browse programs in the Best Welding Schools directory.
- Self-study: The Welding Inspection Technology (WIT) book plus your chosen code book can cost a few hundred dollars total. Cheapest route, but demands discipline.
Pick the Right Code Book
Choose the code that matches the work you plan to inspect: AWS D1.1 for structural steel, API 1104 for cross-country pipelines, ASME Section IX for pressure vessels and piping. You bring this book into the open-book portion, so pick one industry and commit.
Study Strategies That Work
Tab your code book aggressively by clause and figure number, drill timed practice exams and quiz banks, and rehearse Part B on plastic weld replicas if your course provides them. For related exam guides, see /welding-certification/.
How Much Does CWI Certification Cost? Itemized Fees and Total Range
Prices below reflect AWS fee schedules and seminar tuition published in 2026. Fees change, so check the AWS program price list before budgeting. A self-study path currently starts around $1,700 for the initial exam package and Prometric testing, while adding an instructor-led seminar pushes the total above $4,500 for the two-week in-person option, before travel, study materials, or Part B ATF fees.
| Fee Item | Cost | Notes |
| Initial exam package | $1,255 | Current AWS price as of September 2026. |
| Part B practical exam | $1,165 | Additional ATF fees apply for the practical exam. |
| Prometric testing | $445 | Reflects a $60 seat fee per part for initial or reexam endorsements. |
| CWI in-person seminar | $2,245 | Standard in-person seminar tuition as of September 2026. |
| CWI two-week in-person seminar | $2,875 | Two-week in-person seminar and exam prep. |
| CWI two-week online seminar | $2,245 | Two-week online seminar tuition. |
| CWI seminar retake | $1,010 | Available within 12 months of the original event. |
Becoming a Certified Welding Inspector typically costs more than $3,000 out of pocket. At current AWS prices, the exam plus one in-person seminar ranges from $3,500 to $4,030 depending on membership, while the bundled seminar and exam package runs $3,070 to $3,335.
Welding Inspector Pay by State: Highest and Lowest
State-level pay for welding inspectors is not reported separately, so this table uses the closest published benchmark: welders, cutters, solderers, and brazers plus machine setters, operators, and tenders. Certified Welding Inspectors typically earn more than these base welding wages because the credential qualifies them for inspection and quality-control roles. Across these 10 highest-paying states, median annual wages range from about $62,220 to $80,840, and national projections for welders, cutters, solderers, and brazers show 2 percent growth and about 10,300 new jobs from 2025 to 2035.
| State | Occupation | Median Annual Wage | 25th Percentile | 75th Percentile | Total Employment |
| Alaska | Welders, Cutters, Solderers, and Brazers | 80840 | 61280 | 98500 | 790 |
| Hawaii | Welders, Cutters, Solderers, and Brazers | 79000 | 63030 | 90830 | 520 |
| Arizona | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 70150 | 51020 | 77380 | 280 |
| Connecticut | Welders, Cutters, Solderers, and Brazers | 64880 | 49240 | 81590 | 1790 |
| Wyoming | Welders, Cutters, Solderers, and Brazers | 63820 | 56380 | 78890 | 1850 |
| Washington | Welders, Cutters, Solderers, and Brazers | 63020 | 54740 | 73650 | 7720 |
| Massachusetts | Welders, Cutters, Solderers, and Brazers | 62570 | 53680 | 74050 | 2830 |
| New Hampshire | Welders, Cutters, Solderers, and Brazers | 62360 | 50620 | 74420 | 1110 |
| Louisiana | Welders, Cutters, Solderers, and Brazers | 62250 | 50680 | 77310 | 13690 |
| Maine | Welders, Cutters, Solderers, and Brazers | 62220 | 51800 | 69130 | 1690 |
Top-Paying State for Welding Occupations
Among U.S. states, Alaska posts the highest median annual wage for welders, cutters, solderers, and brazers at $80,840.
AWS CWI vs CSWIP vs ASNT: Which Welding Inspector Credential Is Right for You?
AWS CWI, CSWIP Welding Inspector, and ASNT NDT certifications serve different purposes: the first two are welding inspection credentials, while ASNT credentials are method-specific nondestructive testing qualifications. AWS CWI dominates North America, CSWIP is widely specified in the UK, Middle East, and Asia, and ASNT often complements a CWI for NDT responsibilities. TWI also lists a route from AWS CWI to CSWIP, so the two welding inspector credentials can be pursued as complementary qualifications. Before choosing, review employer demand in your region and industry.
| Feature | AWS CWI | CSWIP Welding Inspector | ASNT NDT Certification |
| Issuing body | American Welding Society (AWS) | TWI Certification Ltd | American Society for Nondestructive Testing (ASNT) |
| Global recognition | Internationally administered, dominant in North America and wherever contracts specify AWS CWI | UKAS-accredited to ISO/IEC 17024, common in UK, Middle East, and Asia | Globally recognized method-specific nondestructive testing credential |
| Exam format | Up to three parts: fundamentals, practical, and code book; repeat attempts require 16 hours documented training for one or two part re-examination, 40 hours for three part | Scheme-specific examination structure defined in renewal requirements; includes certification, renewal, and recertification processes | Method-specific examinations; Level II recertification can be completed by retaking each method exam |
| Recertification | Valid for nine years; renewal applications at years three and six by work experience or exam | Renewal at five-year point with work experience and CPD; recertification at ten-year point requires exam | Level II recertification by retaking method examination; no universal interval stated for every ASNT credential |
| Best for | Professionals seeking AWS welding-inspector credential, especially North America or contracts requiring AWS CWI | Professionals targeting employers and projects using the CSWIP/TWI pathway, especially UK, Middle East, and Asia | NDT practitioners needing method-specific qualifications; complements CWI when role includes NDT oversight |
Maintaining CWI Certification: Renewal and Recertification
CWI certification isn't a one-and-done credential. AWS structures it as a nine-year certification cycle that requires two renewal applications along the way, one full recertification at the end, and proof that you've stayed active and current in the field the entire time.
The Three-Year Renewal Cycle
Every three years (at the three-year and six-year marks), you must file a renewal application showing 80 Professional Development Hours completed in subject areas defined by AWS B5.1:2013-AMD1. That training can be in person or online, and AWS also requires that you haven't had a break in welding-related work experience longer than two years within the prior three. As of 2026, work-experience renewal runs $650 for members and $915 for non-members; if you'd rather requalify through an exam instead of documenting CE hours, Part B exam renewal runs $1,040 to $1,305 depending on membership, or $2,170 to $2,435 if you bundle in Part B training.
You can apply as early as 11 months before your certification expires, though AWS recommends submitting at least 60 days ahead. Miss the deadline and there's a 60-day grace period during which your certification shows as expired but is still recoverable, and in some cases AWS will accept late applications up to a year after expiration, according to the CWI Examination User Guide.
Nine-Year Recertification
Once you hit eight years and one month, you become eligible for the nine-year recertification application, the credential's full reset point. AWS offers both exam and non-exam paths: the Part B exam route costs $1,165 to $1,430, the exam-plus-training bundle runs $2,315 to $2,580, and the non-exam CE-based route costs $795 to $1,060.
Because fee schedules and acceptable CE categories change periodically, check the AWS certification portal directly before you plan your renewal budget or timeline.
- Fastest Welding Programs
