What temperatures does an oxy-acetylene flame reach, and why does a century-old process still hang on the wall of modern shops? The oxygen-acetylene flame burns near 6,300°F, hot enough to fuse steel by melting the base metal (and filler rod) into a single puddle, no electricity required.
The process took hold in the early 1900s, a milestone in the history of welding, and while MIG welding and other arc processes long ago replaced it for production work, it remains a common choice for thin steel, tubing, and field repair where a torch beats hauling a power source.
That versatility is also the trap: the same gas path that heats, cuts, and brazes demands respect for pressure settings and flame chemistry.
Oxy-Acetylene Equipment and Gas Handling
Portable homeowner kits and a full shop manifold can both run the same oxy-acetylene torch, but cylinder size, hose routing, and regulator habits change the daily welder safety picture. The welding process is simple: cylinders hold the gases, regulators drop pressure, hoses carry the gases to the torch, and the tip shapes the flame. Understanding that path before you open a valve prevents most accidents.
Core Components From Tank to Torch
- Oxygen cylinder: Stores oxygen at high pressure and uses a green hose with right-hand threads.
- Acetylene cylinder: Contains acetylene dissolved in a porous filler and acetone, has a red hose, and uses left-hand threads with a grooved nut.
- Regulators: One per gas reduces cylinder pressure to a lower working pressure; the acetylene regulator has left-hand connections.
- Hoses: Oxygen hose is green, acetylene hose is red. Never swap or build adapters that force a crossover.
- Check valves: One-way valves at the torch or regulator stop reverse gas flow before it can mix in the hose.
- Torch body and welding tips: The torch body mixes the gases; welding tips come in numbered sizes matched to metal thickness. The cutting attachment is a separate assembly that adds an oxygen lever.
Inspect hoses before each session for cracks, burns, or loose fittings, and replace worn hoses instead of taping them.
Set Pressures From Tank to Torch
Before opening any cylinder, close both torch valves and back out the regulator adjusting screws. Stand to the side and crack each cylinder valve for a moment to clear dust from the outlet. Then open the oxygen cylinder valve fully to seat the backseating valve, and open the acetylene cylinder valve only about one-quarter to one-half turn so it can be closed quickly in an emergency.
Do not turn the acetylene regulator adjusting screw in before opening the cylinder valve; doing so can send uncontrolled pressure downstream. Set the oxygen working pressure first, then the acetylene, using a tip size chart as the pressure reference. Keep acetylene working pressure at or below 15 psi; acetylene becomes unstable above that. Purge each hose one at a time before lighting to remove any air or mixed gas.
Handling, Leak Checks, and Storage
Never use oil or grease on fittings, threads, regulator seats, or o-rings. Oil and high-pressure oxygen can ignite on contact. Check every new connection with soapy water; escaping gas creates bubbles that pinpoint the leak. Do not use a flame to look for leaks.
Store cylinders upright, chained or strapped so they cannot fall, and keep valve caps on when regulators are not attached. Transport cylinders on a cart, never roll them on their side or drag them by the valve. Keep oxygen and acetylene separated, or separated by a fire-rated barrier, and never store cylinders near flames, sparks, or in an enclosed vehicle. Fit reverse-flow check valves, and add flashback arrestors where recommended, to protect the hose and torch if a backfire occurs.
Flame Types: Neutral, Carburizing, and Oxidizing
The flame coming out of an oxy-acetylene torch is not one fixed thing. It changes shape, color, and chemistry depending on how much oxygen you mix with the acetylene, and those three variations (neutral, carburizing, and oxidizing) each do different work on different metals. Reading the flame by eye is a core skill in welding processes, and you set it the same way every time: light the acetylene, open it until the smoke and soot clear, then add oxygen and watch the cone.
The Neutral Flame
A neutral flame burns roughly one part oxygen to one part acetylene and is the setting you will use for most steel work. Start with acetylene only: the flame will be yellow, smoky, and lazy. Add acetylene until the soot stops and the flame lifts slightly off the tip, then begin opening the oxygen valve. A long, feathery white plume, the acetylene feather, will appear around a brighter inner cone. Keep adding oxygen slowly and that feather will shrink back toward the tip. The instant it disappears into the cone, you have a neutral flame.
Visual cues: a sharply defined, light blue inner cone about 1/8 to 1/4 inch long depending on tip size, with no feather at all, surrounded by a larger blue-violet envelope. If the cone looks fuzzy or has a ghost of a feather still attached, you are slightly carburizing. Neutral is the default for mild steel, cast iron, and most general fabrication because it neither adds carbon to the puddle nor burns it out.
The Carburizing Flame
Back the oxygen off (or add acetylene) from neutral and the feather returns. That excess acetylene makes a carburizing or reducing flame, and welders describe its strength by feather length: a 2X flame has a feather twice the length of the inner cone, a 3X flame three times. The inner cone looks softer and less crisply edged than neutral.
This flame introduces carbon into the weld zone, which is exactly what you want for hardfacing, for building up with high-carbon or tool-steel filler, and for aluminum and some nickel alloys where the reducing atmosphere helps limit oxidation. A slight feather, barely visible, is also common when brazing aluminum. On plain mild steel, a heavy carburizing flame will leave a hard, brittle, carbon-enriched bead.
The Oxidizing Flame
Push past neutral by adding more oxygen and the inner cone shortens, narrows, and sharpens to a point. The flame gets noticeably louder, more of a hiss than a soft roar, and the cone takes on a harsher purple-blue tint. That is an oxidizing flame, and it runs hotter than neutral.
Its legitimate use is narrow: a slightly oxidizing flame on brass and bronze, where the excess oxygen forms a thin protective oxide skim over the puddle that keeps zinc from boiling out of the alloy. Some braze welding of copper alloys calls for it as well.
Do not run an oxidizing flame on steel. The surplus oxygen attacks the molten pool directly, producing a foamy, sparking puddle, heavy scale, porosity, and a weak, dirty bead. If your steel weld is throwing sparks off the puddle and the bead looks pitted, check the flame before you blame your technique.
Oxy-Acetylene Pressure Settings and Tip Size Chart
Tip and pressure charts have become less standardized across the industry than most newcomers expect, since Victor, Harris, ESAB, and other torch makers each engineer their own orifice geometry and publish their own flow numbers. That means a "size 2 tip" on one brand's chart doesn't always match a size 2 on another. The chart below is a general reference for common steel thicknesses, useful for getting into the right neighborhood before you fine-tune at the regulator.
How to Read the Chart
Start by matching your material thickness to a tip size, then dial in oxygen and acetylene pressure at the regulators before lighting the torch. Oxygen and acetylene pressures typically run close together in the low single digits for most welding work, with oxygen up to the low twenties on larger tips and acetylene held lower, a much narrower range than most people assume coming from a cutting-torch background, and very different from TIG Welding or MIG welding. Light the acetylene first, purge it clean, then introduce oxygen gradually while adjusting the flame at the tip.
General Pressure and Tip Size Reference
- Tip 000 to 00 (very thin sheet, roughly 1/32 in and under): Oxygen and acetylene pressures both commonly fall in the 3 to 5 psi range on manufacturer welding-nozzle charts.1 This range is suited to fine work like thin sheet or jewelry-scale welding, not structural plate.
- Tip 0 to 1 (light sheet metal, 1/32 to 1/16 in): Slightly higher flow than the smallest tips, still low single-digit psi on most torches, with a soft neutral flame for control on thin edges.
- Tip 2 to 3 (sheet to light plate, 1/16 to 3/16 in): Moderate pressures, generally trending upward from the very thin range as tip orifice size increases.
- Tip 4 to 5 (plate up to about 1/4 in): Higher gas volume is needed to maintain a stable flame at the larger orifice, with pressures for both gases climbing accordingly.
- Tip 6 and larger (heavier plate, 1/4 in and up): Some references list pressures in the 11 to 25 psi range for oxygen with acetylene held lower2, though these numbers vary considerably by brand and nozzle series.
As a rule of thumb, tip sizes 0 through 2 are built for thin sheet metal work where burn-through is the main risk, while sizes 3 through 5 are sized for plate up to roughly 1/4 inch, where you need enough heat input to get full penetration without excessive dwell time.
Always Verify With Manufacturer Data
Treat every number above as a starting point, not a spec. Victor's own flow data sheets1, Harris's Series 41/44 tip charts3, and shop references like GarageWeld's pressure chart4 don't always agree tip-for-tip, and regulator calibration, hose length, and altitude all shift the real-world numbers further. Before you strike an arc, sorry, light a flame, on a new tip, pull up the flow chart for your specific torch model and nozzle series and set pressures to that data. Running a tip too lean starves the flame and causes popping or backfire; running it too rich wastes gas and can produce a sooty, carburizing flame you didn't intend. A five-minute check against the manufacturer's chart saves a ruined weld and a possible flashback.
Step-by-Step Oxy-Acetylene Welding Technique
Preparing the Joint
Gas welding forgives less than you'd think when the base metal is dirty or poorly fitted, and the same strict prep carries over to MIG welding. Start by grinding or wire-brushing both edges back to bright metal, removing mill scale, paint, and oxidation for at least an inch on either side of the joint. On stock thicker than about 3/16 inch, bevel the edges to a 30 to 45 degree angle so the flame can penetrate the full joint depth without excessive heat buildup. Fit the pieces with a small gap (roughly the thickness of the filler rod) and tack weld every few inches to lock in alignment before running the full bead. Skipping tacks is how you end up chasing warpage across a whole panel.
Lighting and Setting the Flame
Open the acetylene valve slightly and light the gas with a striker, never a lighter or match. Increase acetylene until the sooty flame clears, then slowly bring in oxygen until the feather disappears and you're left with a sharp, well-defined inner cone. That neutral flame is your default for most steel welding. Hold the torch so the tip sits roughly a quarter inch above the work, angled 45 to 60 degrees from the surface with the flame pointing in the direction of travel. A steeper angle concentrates heat for thicker material; a shallower angle spreads it out on thinner stock.
Building and Controlling the Puddle
Play the inner cone tip just above the joint until a small, bright puddle forms, typically a shiny circle about the diameter of the rod you're using. Once the puddle is established, dip the filler rod into its leading edge, not into the flame itself, and withdraw it as the pool advances, a rhythm shared with TIG Welding. Move the torch in small circles or overlapping half-moon arcs, advancing steadily so each new puddle overlaps the last by about half its width. This keeps the bead consistent and prevents cold lap where filler sits on top of unmelted base metal instead of fusing into it.
Push Technique for Thin Metal
On sheet stock under about 16 gauge, switch to a push technique: angle the torch so the flame leads ahead of the puddle and the rod trails behind, moving quickly enough that heat doesn't have time to pool and blow through. Reduce tip size and pressure settings accordingly, and consider tack welding more frequently to control warpage. Patience matters more than speed here; a rushed puddle on thin material burns through in an instant and leaves a hole that's harder to fix than to avoid.
Inspecting the Finished Bead
Once the joint cools, inspect it visually before putting any load on it. A good bead shows uniform ripples, consistent width, and full penetration without undercut along the edges. Watch for porosity (small pinholes from trapped gas), which usually points to contaminated base metal or an incorrect flame chemistry. Surface cracks, especially at the crater where you stopped, suggest cooling too fast or excess carbon pickup from a carburizing flame. Grinding a cross-section on scrap joints while you're still learning is the fastest way to see what's actually happening inside the bead, not just on top of it.
Safety, Troubleshooting, and Flashback Response
OSHA's oxygen-fuel gas welding and cutting rule, 29 CFR 1910.253,1 governs nearly every safety decision you make at the bench, from how cylinders are stored to what gear you strap on before striking a spark. Oxy-acetylene work is forgiving when the basics are followed and unforgiving when they are not, so the routine matters as much as the technique, as in Stick Welding and MIG welding.
Required Personal Protective Equipment
Before lighting the torch, gear up properly.
- Eye protection: shaded welding goggles in the shade 4 to 6 range, matched to the work and tip size.
- Hand protection: leather welding gloves rated for heat and spark exposure.
- Body protection: flame-resistant clothing with no frayed cuffs, cuffed pants, or exposed synthetic fabric that can melt.
- Ventilation: adequate airflow to clear fumes and prevent oxygen enrichment or fuel-gas accumulation in the work area, with forced ventilation or a confined-space plan when natural airflow is not enough.
Backfire Versus Flashback
A backfire is a momentary pop or snap at the tip, usually caused by the flame briefly igniting inside the tip from overheating, an obstruction, or the wrong tip-to-pressure combination. It is startling but typically self-resolving once you shut down and cool the torch. A flashback is far more serious: the flame travels back into the torch body, hoses, regulators, or even the cylinders themselves, and it can trigger a cylinder fire or explosion.7
If a flashback occurs:
- Close the oxygen valve on the torch first.
- Close the acetylene valve second.
- If it is safe to do so, shut off the cylinder valves as well.
- Do not relight until the equipment has been inspected, leak-tested, and cleared of the cause.
Flashback arrestors, installed per manufacturer specification at regulator outlets and torch inlets on both oxygen and fuel-gas lines, are selected by gas designation, connection type, flow capacity, and pressure rating.23 OSHA does not mandate a single design, but it does require components matched to the equipment they protect.1
Cylinder Storage and Fire Watch
Oxygen and fuel-gas cylinders need at least 20 feet of separation, or a noncombustible barrier at least 5 feet tall that extends 18 inches above the tallest cylinder and carries a half-hour fire-resistance rating.4 Acetylene cylinders must be stored and used upright,5 capped when not connected,6 and kept in a well-ventilated space away from ignition sources.5 Oxygen cylinders need protection from oil and grease.4 A fire watch should stay posted during and after hot work, particularly near combustibles.
Common Troubleshooting Issues
- Popping or sputtering flame: often a dirty or overheated tip, low gas pressure, or a loose connection.
- Irregular or lifting flame: check tip size against your pressure settings and confirm the tip orifice is not partially blocked.
- Hissing or leaking connections: leak-test with approved solution at working pressure, never with an open flame, and replace damaged washers or fittings before relighting.
Always purge each hose separately and ignite only with a friction or spark igniter, never a lighter or matches.5
Oxy-Acetylene vs. TIG and MIG Welding
Oxy-acetylene is the cheapest way to put heat into steel and the only one of the three that works with no electricity at all, but it is the slowest and least precise of the three on thin material. That trade is the whole comparison: portability and low entry cost come at the expense of speed and repeatability.
Where each process wins on thin steel
For mild steel under 1/8 inch, short-circuit MIG welding is generally the fastest and most forgiving approach. Low heat input, short weld segments, and the right wire diameter keep distortion down, and modern machines with arc-control or auto-set features shrink the setup burden considerably. TIG Welding gives the greatest control: the focused arc and independent filler feed let you place heat exactly where it belongs, which is why it produces the cleanest results on sheet and stainless. On carbon steel you do not need an AC/DC machine, since DCEN is the normal setup; AC matters for aluminum.
Oxy-acetylene absolutely joins thin mild-steel sheet, and generations of auto-body and aircraft work prove it. The limitation is the flame itself: it heats a much wider area than an arc, so warping and burn-through are easier to trigger and the result is less repeatable than MIG and less precise than TIG.
Cost, portability, and learning time
Retail machine prices give rough anchors. Entry multi-process and MIG Welders and Power Supplies from major brands have recently listed in the $1,600 to $2,700 range3, with shop-class machines climbing past $6,0004; TIG machines such as the Lincoln Square Wave 205 have listed near $2,2005 and Miller TIG packages near $2,5006. Those are machine prices only. A complete oxy-acetylene outfit (cylinders or rental, regulators, hoses, flashback arrestors, torch handle, tips, refills, PPE) is not captured by any single published figure, so treat the cost comparison as directional rather than exact.
Practical learning times vary with prior experience, fit-up, position, and the quality standard you are being held to. Rough working estimates, not published standards: MIG competence on thin steel in roughly one to four weeks of regular practice, oxy-acetylene in roughly two to eight, TIG in four to twelve.1 Classroom theory helps but does not substitute for torch time; the AWS Welding Fundamentals I course, for example, runs about 14 hours and costs $420 for members or $560 otherwise.2
Side-by-side summary
| Attribute | Oxy-Acetylene | TIG | MIG |
| Thin steel capability | Workable, higher distortion risk | Excellent, best control | Very good with short-circuit transfer |
| Equipment cost | Lowest entry cost | Moderate to high | Moderate to high |
| Learning curve | Moderate (~2-8 weeks) | Steepest (~4-12 weeks) | Easiest (~1-4 weeks) |
| Portability | Highest, no power needed | Requires power, gas | Requires power, gas |
| Speed | Slowest | Slow to moderate | Fastest |
| Repair suitability | Excellent, also heats, brazes, cuts | Good on clean, accessible joints | Good where power is available |
Most working shops end up owning a torch outfit regardless of which arc process they favor, because nothing else heats, bends, brazes, and cuts on one cart.
Metal Suitability and Filler Rod Selection
This table matches common metals to filler rod choices and flame settings for oxy-acetylene work. Suitability reflects whether the torch can produce a sound fusion weld with the stated setup. For aluminum, oxide formation resists fusion, and TIG is often the better choice.
| Metal | Suitability | Filler Rod | Flame Type | Notes |
| Mild steel | Yes | R45 uncoated mild-steel gas rod | Neutral | Readily fusion welded; neutral flame preferred. |
| High-carbon steel | Yes | Steel filler rod available for high-carbon steel | Slight carburizing | Excess carbon in the carburizing flame suppresses oxidation. |
| Stainless steel | Yes | Filler rod specifically alloyed for stainless steel | Neutral | Flux is required. |
| Aluminum | Limited | N/A | Neutral or slightly reducing | Oxidizing flame forms aluminum oxide and causes poor fusion. Avoid welding aluminum to magnesium. TIG is a better route for most aluminum work. |
| Copper | Yes | BCuP-2 or BCuP-5 sil-phosphorus rods | N/A | Self-fluxing on copper. Used for copper-to-copper refrigeration and HVAC lines. |
| Brass | Yes, for low brasses | 1.5% silicon rod | Neutral | Low brasses with 80 to 95 percent copper and 5 to 20 percent zinc weld readily in all positions. Nickel-silver needs a suitable flux and a high-zinc bronze filler. |
| Cast iron | Yes | Cast-iron filler rod, including nickel-based or high-chromium types | Neutral | Flux is required. Welding cast iron calls for special preheating and slow cooling. |
| Wrought iron | Yes | R45 mild-steel gas rod | N/A | Readily welded by oxy-acetylene. |
Brazing, Heating, and Modern Uses of the Gas Torch
The oxy-acetylene torch outlived its role as a primary welding tool by becoming the most versatile heat source in the shop. Even where arc processes such as MIG welding and TIG welding have replaced it for joining structural steel, the gas flame still cuts, bends, brazes, and solders in trades that arc machines cannot touch as easily. Understanding brazing and the torch's secondary jobs is what keeps this equipment relevant in 2026.
Welding vs. Brazing
The key difference is simple: in fusion welding you melt the base metal, while in brazing you never do. Brazing joins two pieces by melting a filler rod that flows between them, bonding to their surfaces without liquefying the parts themselves. Because the base metal stays solid, brazing runs at lower temperatures, warps the workpiece less, and lets you join dissimilar metals like steel to brass that would be difficult to fusion weld.
A sound brazed joint follows a predictable sequence:
- Clean the metal: Remove oil, paint, rust, and scale. Filler will not bond to a dirty surface.
- Apply flux: Coat the joint (and often the rod) with flux to dissolve oxides and let the filler wet the metal.
- Heat to brazing temperature: Bring the base metal, not the flame, up to the point where the filler melts on contact. Heat the parts evenly, not the rod directly.
- Let capillary action work: Touch the rod to the heated joint. The molten filler is drawn into the tight gap by capillary action, spreading through the fit-up on its own.
Good fit-up matters more in brazing than in welding, since capillary flow depends on a narrow, consistent gap between the parts.
Cutting, Heating, and Soldering
The same torch body accepts different tips and attachments, which is why one kit covers so many tasks. Swap the welding tip for a cutting attachment and the torch adds a high-pressure oxygen lever that blows through preheated steel. Fit a rosebud, or multi-flame heating tip, and it delivers broad, even heat for bending, forming, or freeing rusted fasteners. Smaller tips handle soldering and delicate work.
Modern applications where the gas torch still earns its place include:
- Flame cutting and gouging of plate and pipe
- Heating steel for bending, straightening, and shrinking
- Soldering copper lines and electrical connections
- Jewelry repair and small-scale metal art
- HVAC and refrigeration work, where copper joints are brazed in the field
Where It Stays Popular
Oxy-acetylene remains a fixture in auto body repair, where technicians heat panels, braze patches, and free seized bolts without hauling power to the job. Metal artists rely on its portability and the control of a manual flame for sculpture and ornamental work. Field maintenance crews value that a bottled gas rig needs no electricity at all, making it the tool of choice for remote repairs, farm work, and anywhere a generator is a hassle. That combination of portability, versatility, and independence from the grid is why the gas torch has not disappeared, and likely will not.
