Best Online Orbital Welding Schools for Certification & Training
Compare top online orbital welding schools, certifications, costs, and career paths.
Manual TIG demands a steady hand. Orbital welding demands something else: the discipline to program, monitor, and document a machine that lays down a code-quality bead on stainless tube inside a semiconductor fab, pharmaceutical skid, or food-grade line, often to a tolerance no hand torch can hold consistently. Employers in those industries pay for that discipline, and openings in high-purity piping regularly outpace the supply of welders who can pass an orbital procedure qualification.
Training runs anywhere from a few hundred dollars for theory-only coursework to $17,500 for a private, on-site program, and the gap between those numbers usually comes down to hands-on lab time and equipment access.
Getting from curious to hireable means sorting real programs from marketing, understanding which certifications employers actually check, and knowing what pay and job volume look like once you're qualified.
Top 3 Fully Online Orbital Welding Schools
These three fully online welding certificates meet this ranking's online-only filter; none require campus visits. They focus on welding theory, safety, and entry-level skills that can feed into orbital welding training or employer-specific high-purity tube welding programs. Treat them as preparation, not as a replacement for hands-on orbital welding operator certification.
  • Earnings ten years after entry lead
  • Program completion rates weighted heavily
  • Fully online delivery required
  • Baseline school quality considered
Morgan Community College
Fort Morgan, CO · $5,000 – $10,000/yr (est.)
Hispanic-Serving Institution
Best for: Rural Colorado learners wanting foundational welding theory
A small public community college offering a 21-credit Basic Welding certificate delivered fully online. The program focuses on SMAW, blueprint reading, oxyfuel and plasma cutting, and maintenance welding, with a 2.0 GPA and minimum C grade requirement. It is not eligible for federal financial aid, so budget accordingly.
  • 21 total credit hours
  • Minimum grade of C in each course
  • 2.0 cumulative GPA required
  • Not eligible for federal financial aid
  • 25% of credits must be taken at MCC
Rhinelander, WI · ~$8,000/yr (est.)
Best for: Self-paced learners seeking competency-based training
A technical college offering a 30-credit Welding technical diploma fully online with competency-based pacing and multiple start dates. Coursework spans SMAW, GMAW, FCAW, and GTAW, plus blueprint reading, safety, metallurgy, and weld inspection aligned to AWS D1.1 structural steel. Financial aid is available, and the program is designed to prepare for certification or job-entry performance tests.
  • $7,855 total program tuition
  • 30 total credit hours
  • Starts fall or spring
  • $43,508 median earnings
  • Financial aid available
  • Robotic welding and computerized cutting
  • Weld quality per AWS D1.1 code
Camden County College
Blackwood, NJ · $5,000 – $10,000/yr (est.)
Best for: Apprenticeship-bound learners needing transferable online credits
A community college offering a 12-credit Welding Apprentice certificate fully online as related technical theory for apprenticeships. The one-year, 30-week format covers welding setup, cutting techniques, safety, electricity, and advanced theory, with credits that may transfer into an associate degree. Students register through Workforce Development, making it a fit for employer-sponsored or apprenticeship-track learners.
  • 1-Year program
  • 12 total credit hours
  • Fully online option available
  • Related technical theory for apprenticeships
  • Credits may transfer to associate degrees
  • Register via Workforce Development
What Is Orbital Welding and Why Certification Matters
The tradeoff most beginners miss is that orbital welding trades manual dexterity for procedural discipline: you are not chasing a perfect bead by hand, you are proving you can set up, monitor, and document a machine that welds it for you. That shift in skill set is exactly why certification carries so much weight in this corner of the trade.
What Orbital Welding Actually Is
Orbital welding is an automated variant of gas tungsten arc welding (GTAW/TIG) built for high-purity tube and pipe. Instead of a welder moving a torch by hand, a mechanized welding head clamps onto the tube and rotates, or orbits, around the joint while a programmable power supply controls amperage, travel speed, and arc timing. The result is a consistent, repeatable, contamination-free weld inside tubing that often carries gases, chemicals, or biologics.
Why Industries Depend On It
This process exists because certain industries cannot tolerate weld defects, inclusions, or surface roughness inside their piping. Semiconductor fabs, pharmaceutical and biotech manufacturers, food and beverage processors, and clean energy facilities (hydrogen, solar-grade gas systems, battery manufacturing) all rely on orbital welds to protect product purity and system integrity. A single bad weld in a semiconductor gas line or a biopharma bioreactor loop can shut down production or contaminate a batch.
Why Certification Is the Gatekeeper
Because the stakes are so high, employers rarely take a resume at its word. Orbital welding certification typically requires passing a performance test conducted under a specific welding procedure specification, or WPS, that mirrors the exact tube diameter, wall thickness, and material the employer uses. Passing that test proves you can produce welds meeting code requirements like ASME BPE, and it signals you understand purge gas control, fit-up tolerances, and documentation, not just button-pushing. For career-changers seeking Welding Jobs, that credential is often the difference between an interview and a rejection.
Orbital Welding Certifications Employers Require
ASME Section IX, updated to the ASME Section IX 2025 Edition effective July 1 of that year, is the credential most orbital welding employers in the United States ask for first. It governs welder and welding operator performance qualification for pressure piping, boilers, and vessels1, and because orbital GTAW is classified as a mechanized or automatic process, the operator is qualified as a welding operator rather than a manual welder, with variables tied to the specific equipment and how much control the operator exercises over parameters2.
ASME vs. EN ISO vs. AWS
Outside North America, EN ISO 14732:2025 fills the same role and is the standard most often specified on European and international projects, including semiconductor and pharmaceutical builds with multinational ownership. AWS codes matter less directly here: AWS D1.1 (Structural Welding Code) covers structural steel, not high-purity tube, so it rarely governs orbital tube work. Some sanitary and biopharma specifications reference AWS D18.1 for sanitary stainless tube and pipe instead, so check the governing contract or purchaser spec before assuming which code applies.
Validity and Continuity Rules
ASME Section IX has no fixed expiration date.1 A qualification stays active as long as the welder or operator uses that specific process within every six-month window1, and continuity is tracked per process, not as a blanket welding credential. Let one process lapse past six months and it must be requalified even if you welded other processes continuously.
EN ISO 14732:2025 works differently. Certificate holders confirm continued work within their qualified range every six months, formal certificate validity runs three years, and full retesting (or an alternative revalidation route) comes due within six years. Employers and quality systems keep the traceable records that prove continuity for either standard.
Employer-Specific Programs
Beyond the code bodies, some employers require vendor-specific training. Swagelok orbital welding training is widely recognized in semiconductor fabrication and biopharma piping shops, since it certifies competence on the specific orbital welding heads and power supplies those industries standardize on, layered on top of, not instead of, a code qualification. Our welding certification test guides break down what each exam actually covers before you sit for it, so you can see where each one fits in how to become a certified welder.
Cost of Orbital Welding Training and Financial Aid
Welding programs overall can range from about $5,000 to $20,000, and orbital welding costs vary by format: a provider-center group seat can run about $2,500 per attendee, while a private five-day customer-site class can reach $17,500 plus travel. Financial aid is not universal, and net price is often more realistic than published tuition; monthly loan payment figures are not published, so median debt is shown where available. The first three rows show the lowest-cost community college welding programs in the ranking, and the remaining rows show orbital provider, certification, and equipment costs.
School or providerType or scopePublished costNotes
Camden County CollegeCommunity college welding program, Blackwood, NJ$4,320 in-state; $4,416 out-of-stateNet price $5,996; median debt $11,851
Nicolet Area Technical CollegeCommunity college welding program, Rhinelander, WI$4,793 in-state; $7,066 out-of-stateNet price $8,255; median debt $7,837
Morgan Community CollegeCommunity college welding program, Fort Morgan, CO$4,252 in-state; $16,852 out-of-stateNet price $9,266; median debt $8,501
OWETEC 2-Day Customer-Site TrainingCustomer-site orbital welding course$6,000Customer travel not included
OWETEC 3-Day Customer-Site TrainingCustomer-site orbital welding course$9,000Customer travel not included
OWETEC 4-Day Customer-Site TrainingCustomer-site orbital welding course$14,500Customer travel not included
OWETEC 5-Day Customer-Site TrainingCustomer-site orbital welding course$17,500Customer travel not included
OWETEC Training CenterProvider-center group course$2,500 per attendee; $10,000 minimum groupTechCred approved in Ohio; amount and limits not specified
OWETEC Qualification ExamsProvider testing$425 procedure qualification; $200 welder performance qualificationRetest and per-unit policies not published
Swagelok Southwest Orbital Weld TrainingProvider-facility course$500 registrationCertification test listed as included; instruction, equipment, consumables, guide, certificate included; travel and meals not stated
Welding certification testsIndustry exam fee range$35 to $1,350Not orbital-specific
Welding equipment and consumablesGeneral welding program supplies$300 to $2,000Many provider courses include equipment and consumables
Online Orbital Welding Theory: What You Can Learn Remotely vs Hands-on Requirements
Fully online orbital welding certification does not exist in any meaningful, code-recognized form, but the theory-only portion of training has moved online faster than most trades. Best online welding schools now split coursework into remote lectures paired with an in-person lab, rather than requiring students to travel for the entire program.
What Transfers to a Screen
Orbital welding theory translates well to video and self-paced modules. Programs like Precision Welding Supply's online training and Arc Machines' online orbital coursework cover GTAW principles, equipment setup and controls, process variables, troubleshooting logic, and high-purity documentation practices. Some course listings, including Swagelok's UK-based training, note that writing weld procedures is also taught in this format. Blueprint reading and metallurgy fundamentals fit the same remote model.
Where the Torch Has to Be in Your Hand
What online coursework cannot replace is producing an actual weld. Purging tubing, prepping joints, running a real orbital head on real material, and having a coupon cut, etched, and radiographed per ASME Section IX all require physical presence. The Pipefitters' Training Fund's Automatic Orbital Welding program makes this explicit: about 75 percent of its 36 to 40 class hours is hands-on production of samples, leading to a UA-18A qualification, with no remote substitute offered.1 Swagelok's five-day course is described as available virtually or in person depending on location, and treats ASME IX performance testing as an optional add-on rather than something completed on a screen.
Vetting a Hybrid Program
Before enrolling in a program advertised as online or hybrid, ask directly what portion happens on campus or at a partner facility, how many lab hours are included, and whether coupon testing to ASME IX or a similar code is built in or billed separately. Confirm the lab site has orbital equipment matching what you would use on the job, not just manual GTAW stations. Programs like Tulsa Welding School's hybrid model pair online lecture hours with a much larger block of supervised lab time, a ratio worth expecting from any orbital-specific course before you commit tuition.2
Career Outcomes and Salary Potential for Orbital Welders
Orbital welders are typically counted within the Bureau of Labor Statistics category for welders, cutters, solderers, and brazers. Total U.S. employment was 437,700 in 2025, with about 40,300 average annual openings projected from 2025 to 2035. Across industries, semiconductor and other electronic component manufacturing paid an industry-wide median of $73,980 in 2024, while occupation-specific pharma and food wage data were not available.
Median welder wage of $48,940 in 2023, with percentiles from $36,830 to $72,970 and 2% growth through 2035.
How to Choose an Orbital Welding School
OWETEC lists instructors who hold AWS/QC1 CWI and CWE credentials, ASNT Level 2 Visual Inspector status, and more than 10 years of orbital expertise. Use that as a benchmark when you compare schools, because the right program should prepare you for real welding work, not just teach you one machine.
Prioritize Brand-Neutral Training
Equipment-neutral programs teach orbital welding on multiple power supplies and weld heads rather than tying you to a single manufacturer. OWETEC is one documented multi-system option, with hands-on work across systems such as Orbitalum and Swagelok. By contrast, Swagelok courses focus primarily on the Swagelok M200, and Orbitalum operator training is built around ORBIMAT CA/SW machines. Manufacturer-specific depth is useful when an employer uses that platform, but brand-neutral training builds transferable skills for semiconductor, pharmaceutical, and food-grade piping work where equipment varies from site to site.
Check Instructor Qualifications and Class Size
Ask who teaches the course. Strong orbital programs list instructors with AWS/QC1 CWI or CWE credentials, ASNT Level 2 visual inspection certification, and field experience. Axxair, for example, states that its instructors hold CWI/CWE and at least five years of orbital instruction. Also ask about class size and lab access. Orbital welding is a hands-on skill, so you need scheduled time on real weld heads and power supplies with instructors watching your technique, not just classroom theory.
Confirm Prerequisites and Placement Support
Most orbital classes assume you already have basic TIG welding pipe skills, can read blueprints, and understand basic metallurgy. If you are newer to welding, complete a conventional TIG course first. Before enrolling, attend a campus visit or virtual info session and ask about employer partnerships and job placement rates. Courses such as OWETEC and some Swagelok options may include ASME Section IX qualification or ASNT Level 2 visual-inspection exam preparation, which can make you more competitive for quality-control and high-purity piping roles.
Prerequisites and Beginner Pathways to Orbital Welding
Grayson College's Orbital Welder Career Ready Certificate runs 448 contact hours in 2026-2027, but many orbital welding training programs set the entry bar lower: no prior orbital welding background is the typical starting point.
Where Beginners Can Start
Several provider courses accept newcomers. Swagelok's five-day orbital welding course is open to all experience levels, and its four-day course is designed specifically for students with no orbital welding experience. Axxair's orbital welding training welcomes beginner-level welders as well as experienced operators. OWETEC's five-day orbital weld training is also open to newcomers, though it expects some SMAW or GTAW exposure before the class.
Skills to Build Before or During Training
A foundational welding certificate helps with the basic math, welding symbols, and manual TIG skills that make orbital training easier. Students should become comfortable with tube prep, purge setup, electrode gap setting, and fixture setup. Grayson College's hybrid certificate combines Welding Fundamentals, Blueprint Reading for Welders, Welding Automation, and Orbital Tube Welding, which covers the college pathway clearly.
Some programs accept students with no orbital experience but still check skills through a pre-course assessment or an end-of-course weld sample. Axxair may submit samples for ASME Section IX or similar standards, and Swagelok offers optional ASME IX testing when QA/QC requirements apply.
A Realistic Path for Beginners
A complete beginner can follow a progression like this: - Complete a basic welding certificate or foundational program that includes GTAW/TIG and blueprint reading. - Get hands-on manual TIG practice, especially on stainless steel tube if available. - Take a four-day or five-day beginner orbital welding course with no orbital prerequisite. - Pass the end-of-course weld evaluation or ASME Section IX qualification required by the employer.
Existing welders can skip the foundational stage and go directly to a beginner orbital course to upskill into high-purity tube work. Career changers should expect a semester or more for basic welding training, welding school duration varies by program, then add the orbital intensive and any qualification testing. Advanced or union journeyman tracks remain a later step. The Pipefitters' Training Fund Welding Programs page, for example, includes an Orbital Tube Weld Program that is a journeyman course requiring a current UA-GTAW certification before enrollment.
Frequently Asked Questions About Orbital Welding Training
Orbital welding training raises practical questions about time, cost, certifications, and job options. The answers below reflect current information from training providers and industry sources, but details vary by program, equipment, and employer requirements.
What is orbital welding training and how long does it take?
Orbital welding training covers orbital TIG setup, operation, programming, inspection, and troubleshooting for high-purity tube and pipe. There is no industry-wide standard length. Common hands-on courses run about four to five days, such as Swagelok's five-day program or OWETEC's 50-hour course, but broader preparation can take weeks or months depending on experience and the applicable code or materials.
How much does orbital welding certification cost?
Costs are not directly comparable because some programs include equipment, materials, testing, or meals while others cover instruction only. Reported 2026 program costs range from about $2,000 to $35,800, and certification exam fees range from roughly $35 to $1,350.1 OWETEC lists total program costs from $6,000 to $17,500, with per-attendee pricing around $2,500 and minimum training costs near $10,000 depending on group and travel terms.
What certification do I need for orbital welding?
There is no single universal credential. Qualification usually follows the applicable code, customer, or employer requirement, most often ASME Section IX for pressure piping or vessels, with related standards like ASME B31.3, ASME BPE, or AWS D18.1 for sanitary and hygienic tube.2 Some employers prefer Welder Certifications through AWS. Course completion alone does not equal passing a code qualification test.
Can you do orbital welding training online?
Yes, some providers offer virtual components. Swagelok's five-day orbital welding training can be taken in-person or virtually, covering principles, setup, operation, and troubleshooting. However, virtual training is generally not a substitute for the hands-on practice and physical weld samples required for code qualification. Practical qualification typically requires testing under the applicable procedure and code.
What jobs can I get with orbital welding certification?
Orbital welders are placed in high-purity industries such as semiconductor, pharmaceutical, biotech, food and beverage, aerospace, nuclear, power generation, and process piping. Job titles and pay vary, and no nationally authoritative 2026 wage or job growth rate exists specifically for orbital welders. Welder Salary estimates from different sources conflict, so treat them as rough ranges rather than guaranteed outcomes.
Next Steps: From Training to Certification and Job Placement
The typical path from beginner to working orbital welder is straightforward: complete a hands-on training program, pass an employer-recognized certification test, then build supervised tube welding hours before targeting semiconductor, pharmaceutical, food and beverage, or aerospace work.
Build a Shortlist
Start with the welding schools directory on gowelding.org and compare these programs. Look at welding school cost, total clock hours, lab time per week, and whether the school brings in orbital equipment from a major manufacturer. Call admissions and ask for the current curriculum and upcoming lab schedule. A school that cannot give you a straight answer about orbital lab access is worth skipping.
Ask directly about employer connections. The strongest programs place graduates with contractors and fab shops, host certification testing on site, or bring in inspectors from semiconductor and pharma contractors. Ask how many graduates sat for an orbital weld test in the last year and which employers hired them.
From Certification to Job Placement
After you pass your certification test, treat the first six to twelve months as paid skill-building. Accept tube fitting and stainless TIG work that puts you near orbital jobs, even if you start as a helper or fitter. Revisit the certification test guides on gowelding.org to schedule any required weld coupons and to confirm what each certification covers.
Then use welding jobs on Indeed to search entry-level orbital welding roles near semiconductor fabs, biopharma plants, food processing facilities, and aerospace fabrication shops. Apply before you feel fully ready: many employers test for skills, not years on the job.
