Structural steel fabricators and erectors are hiring behind a wave of infrastructure and data center construction, and most job postings still name one credential outright: AWS D1.1 certification in the 3G and 4G positions. That single line separates candidates who get a callback from those who don't, regardless of how many welding classes appear on a resume.
The real friction is access. Hands-on structural welding instruction has traditionally meant relocating near a campus lab, but a handful of programs now deliver code theory, blueprint reading, and metallurgy fully online, pairing that coursework with local lab time or a proctored test site for the qualification weld itself.
Cost, credit length, and how a program handles that hands-on gap vary more than most applicants expect, and those differences decide how fast a certification actually gets earned.
Best Fully Online Structural Welding Schools 2027
For career changers who cannot attend hybrid or campus labs, this list focuses on fully online structural welding options. The three programs below range from a 12-credit apprenticeship theory certificate to a 30-credit AWS D1.1-aligned technical diploma.
- Ten-year earnings after entry
- Program completion rates
- Fully online delivery
- Program strengths and outcomes
#1Rhinelander, WI · ~$8,000/yr (est.)
Best for: Working welders needing competency-based pacing
Nicolet College's welding technical diploma stands out for its explicit AWS D1.1 structural steel code alignment, covering shielded metal arc, gas metal arc, flux core, and gas tungsten arc welding. Lab components include robotic welding, computerized cutting, and overhead crane operation, and the program uses competency-based pacing with multiple start dates. Graduates prepare for certification or job-entry performance tests in production, maintenance, and job-shop welding.
- 30 total credit hours
- Weld quality measured against AWS D1.1 code
- Covers SMAW, GMAW, FCAW, and GTAW
- Includes robotic welding and computerized cutting
- Competency-based pacing with multiple start dates
- Prepares for certification and job-entry tests
Morgan Community College
#2Fort Morgan, CO · $5,000 – $10,000/yr (est.)
Best for: Beginner welders wanting an affordable certificate
Morgan Community College's Basic Welding certificate is a compact 21-credit path that moves through SMAW I and II, maintenance welding, blueprint reading, and oxyfuel/plasma cutting. The program requires a C or better in each course and a 2.0 cumulative GPA, and it is designed for entry-level welding shop, fabrication, and maintenance roles. Keep in mind the certificate is not eligible for federal financial aid.
- 21 total credit hours across four semesters
- Requires at least a C in every course
- Maintains a 2.0 cumulative GPA
- Covers SMAW I and II and blueprint reading
- Not eligible for federal financial aid
Camden County College
#3Blackwood, NJ · $5,000 – $10,000/yr (est.)
Best for: Apprentices needing online related technical theory
Camden County College's Welding Apprentice certificate is a one-year, 30-week fully online option that provides related technical theory for apprenticeships. The 12-credit program covers welding system setup, welding and cutting techniques, industrial safety, and electricity in welding, with credits that may transfer into an associate degree such as the TES.AAS pathway. It is ideal for learners who already have or are pursuing employer-based welding training and need the classroom theory component online.
- 12 total credit hours over 30 weeks
- Fully online option available
- Provides related technical theory for apprenticeships
- Credits may transfer to an associate degree
- Registration through Workforce Development
- Covers electric welding processes and safety
- Prepares for maintenance technician roles
How We Ranked These Fully Online Structural Welding Programs
Online trade education has grown fast enough that separating real programs from marketing pages now takes real filtering, not just a glance at a homepage.
We started by removing anything that wasn't fully online. That's a departure from most lists of best online welding schools in this space, which blend hybrid programs, weekend labs, and campus-based tracks under an "online" label because it's convenient. If a program required you to show up to a shop for coursework beyond a proctored certification test, it didn't make this list.
What the Composite Weighs
From what remained, we built a mixed quality composite that leans heavily on delivery format, then layers in baseline quality signals pulled from federal College Scorecard data. The specific metrics feeding that composite:
- Program-level completions: how many students actually finish the structural welding track, not just enroll.
- Program-level earnings: what graduates report earning after leaving the program.
- Institution-level net price: what students actually pay after aid, not sticker tuition.
- Graduation rate: completion across the entire institution.
- Retention: how many first-year students return for a second year.
Two Honest Caveats
Two things worth knowing before you lean on this list. First, graduation rate here reflects the whole institution, not the structural welding program specifically, since program-level completion data at that granularity isn't published. Second, net price is sector-conditional, meaning it's benchmarked against comparable institution types (community college, private trade school, and so on) rather than a single national number. Neither caveat undermines the ranking, but both matter if you're comparing schools directly.
What Is Structural Welding Certification? AWS D1.1, Positions, and Thickness Requirements
For structural work, welder certifications are proof that you can lay down a sound weld under a specific set of conditions, not a diploma that says you sat through a class. A welder qualification test has you weld a coupon in a defined position, thickness, and process, then that coupon gets bent, broken, or X-rayed to see if the weld actually holds. Pass, and you're "certified" to weld within the range that test covers. Fail the bend test and the paper from a training program means nothing to a contractor.
The Code Employers Actually Ask For
In structural steel work, that standard is AWS D1.1, Structural Welding Code, Steel, published by the American Welding Society. The current edition, AWS D1.1/D1.1M:2025-AMD1, is the one shops and inspectors are expected to be working from in 2026. It spans procedure qualification, welder qualification, fabrication, inspection, and acceptance criteria, essentially the whole rulebook for how welded steel structures get built and checked.
Plate Positions: 3G and 4G
For plate certification, two positions come up constantly in structural work: 3G SMAW Certification, a vertical groove weld, and 4G SMAW Certification, an overhead groove weld. Passing both is often treated as evidence you can handle the toughest positions a structural job will throw at you, since flat and horizontal welds are comparatively forgiving.
Thickness Ranges and Backing Bar Rules
D1.1's Clause 10 lays out which production thicknesses and diameters a given test qualifies you for, along with the specimen ranges used in procedure qualification. These ranges shift depending on the thickness of your test coupon and whether a backing bar was used, so treat any thickness number you hear secondhand as a starting point, not gospel, and confirm against the current code or your certifying body before you rely on it.
AWS Certified Welder vs. NCCER vs. Employer Tests
AWS Certified Welder credentials are earned through accredited testing facilities against D1.1 or related codes. NCCER offers a broader, curriculum-based credential more common in training programs and apprenticeships. Many fab shops and contractors also run their own in-house qualification tests mirroring D1.1, since a weld test is only good for the specific process, position, and material it covers, no matter whose name is on the certificate.
The Structural Welding Certification Pathway
Structural welding certification follows a defined sequence. Most students complete theory online, then schedule hands-on practice locally before sitting for the AWS D1.1 3G and 4G performance qualification test. Passing that test leads to certification and then to employer-specific weld tests for specific job sites.
Structural Welding Program Cost and Length: Tuition, Equipment, and Test Fees
The three most affordable fully online welding programs in our 2026 cost ranking list program-level tuition from $4,252 to $7,855 and require 12 to 30 credit hours. Program length varies widely: Camden County College lists a 1-year Welding Apprentice program, while community college certificates often run 3 to 7 months and trade school diplomas run 6 to 12 months. On top of tuition, plan for equipment and materials (one welding program catalog lists $1,525 for equipment and $1,103 for materials), and certification testing: AWS practical welder test fees typically run $200 to $500, while AWS D1.1-focused CWI online seminar fees start at $2,245 for members, with seminar plus exam at $3,070 to $3,335.
| School | Location | Program | Delivery | Program tuition (listed) | Credits | Program length |
| Camden County College | Blackwood, NJ | Welding Apprentice | Online | $4,416 (in-state; out-of-state $4,416) | 12 credit hours | 1 year |
| Nicolet Area Technical College | Rhinelander, WI | Welding | Online | $7,855 total program tuition | 30 credit hours | Not listed |
| Morgan Community College | Fort Morgan, CO | Basic Welding | Online | $4,252 (in-state; out-of-state $16,852) | 21 credit hours | Not listed |
Can You Get Structural Welding Certification Online? Lab Partnerships and Proctored Tests
The honest answer sits between yes and no. You can complete blueprint reading, metallurgy, welding symbols, and AWS D1.1 code theory entirely online, but the performance qualification test itself, the part where you actually run a groove or fillet weld in a required position and it gets inspected or undergoes destructive weld testing, has to happen with your hands on a torch or stinger. No school has replaced that with a webcam.
What "Online" Actually Covers
When programs advertise online structural welding training, they generally mean the classroom portion. American Welding Society coursework offers self-paced online, live instructor-led online, in-person, and dual-format options, but the dual-format tracks still route students to a physical site for hands-on work. Lincoln Tech's Welding Technology Diploma Program leans on simulators and digital platforms to reinforce technique between lab sessions, which helps with muscle memory but isn't a substitute for live arc time.
Hybrid Models in Practice
Hybrid is the more common and arguably more honest label. Tulsa Welding School structures its Professional Welding Training Program with online theory on set deadlines paired with scheduled campus time for hands-on practice under instructors. SkillCat's hybrid model pairs online theory with in-person labs, plus VR practice through its OcuWeld tool for early repetition before students touch real equipment.1 These models differ from fully online tracks mainly in how much campus attendance is baked into the schedule.
Why the Ranking Narrows to Didactic-Only Tracks
Because the lab requirement is non-negotiable, programs marketed as "100% online" almost always mean the didactic coursework only, with hands-on qualification handled through a local lab partnership or an approved proctored test site elsewhere. That distinction matters when comparing programs, since a school that is transparent about splitting theory online and testing in person is more useful to plan around than one that blurs the line.
Equipment, Shipping, and Test Sites
Some programs ship trainer kits or basic gear to students working through online modules at home, then require travel to a partner facility, community college lab, or approved testing center to sit for the actual D1.1 qualification. Exactly how each program proctors that performance test (school staff, a certified welding inspector, or a third-party site) isn't standardized industry-wide yet, so ask directly before enrolling.
Certifications Employers Actually Require for Structural Welders
A structural welding credential is a document that proves you can lay sound welds to code on a specific joint, position, and thickness. Not every credential proves the same thing, though, and employers treat them very differently. Four types dominate the field, and knowing what each one actually certifies saves you from paying for the wrong one.
The Four Credential Types
- AWS Certified Welder: A performance-based credential from the American Welding Society. There are no prerequisite courses or minimum experience requirements; you schedule and pass a performance qualification test at an AWS Accredited Test Facility under QC47. It is not tied to any single employer, project, or location.
- NCCER Structural Welding credentials: Training credentials issued through NCCER's network of learning institutions.1 They validate skills against a structured curriculum and are recognized by contractors2, but they function as training validation rather than a code-specific qualification test.
- WABO Welder Certification Program: A Washington-focused structural welder qualification built on uniform testing procedures and heavily referencing AWS standards. It carries weight for work under Washington code but is regional, not a national credential.3
- School certificate: A record that you completed a course or program. It is not, by itself, an AWS certification, an employer qualification test, or a welding license.
National vs. Regional Acceptance
The practical difference comes down to portability. An active AWS Certified Welder credential travels: it is accepted nationally and internationally wherever that qualification is recognized. NCCER credentials are recognized by contractors in many regions but read as training validation.2 WABO is centered on Washington requirements and does not carry the same broad national acceptance. A school certificate proves you attended, nothing more.
Why the Employer Test Often Matters Most
Many employers do not ask to see a certificate at all. Instead, they require you to pass their own welder qualification test before hiring. Pass it, and you are a qualified welder for that shop's work, whether or not you hold a formal certification. This is why hands-on skill outranks paperwork.
Before you commit to a program, check the Welding Jobs posted by the state and local employers you actually want to work for. Ask which credentials they honor and whether they run in-house qualification tests. A program that prepares you to pass AWS D1.1 in the positions those employers weld is worth more than any certificate on paper.
What to Look for in a Structural Welding Program: Accreditation, GI Bill, and Financial Aid
Paying out of pocket versus using benefits or sponsorship changes which schools belong on your shortlist, so compare welding school cost and the funding path before you vet the curriculum.
Accreditation and Federal Aid
A program's accreditation status, whether through a national trade accreditor like ACCSC or a regional academic body, determines whether it can participate in Title IV federal aid at all. Skipping this check can quietly remove Pell Grants and Direct Loans from your options, so ask directly whether the school is Title IV eligible before you enroll.
GI Bill and Veteran Funding
GI Bill benefits can apply to non-college degree programs, the category most welding training falls under, and are available to veterans, service members, National Guard, Reserve members, and qualified dependents. The catch: the specific school and program format you want, campus, hybrid, or fully online, must have VA school program approval before you start. Post-9/11 eligibility generally requires at least 90 days of service (or 30 days if discharged for a service-connected disability) with an honorable discharge.1 Note that fully online-only instruction caps the housing allowance at 50% of the national average, so a hybrid program with in-person lab time may pay out differently than an online-only one.2 Some schools, including Arclabs, Tulsa Welding School, Hobart Institute, and UTI, describe accepting GI Bill or VA benefits for welding tracks, though the exact process (Letter of Eligibility, VA certification timing) varies by school, so confirm directly.345
Employer Sponsorship and Apprenticeships
Employer sponsorship and union or fab-shop apprenticeships are not VA programs; they depend entirely on the employer or sponsor. Ask whether tuition is paid upfront, reimbursed after completion, or contingent on a service agreement.
Lab Quality and Ratios
For online-heavy formats, ask about instructor-to-student ratio during in-person lab weeks versus virtual theory sessions, and scrutinize the quality of the school's lab partnership. A program that ships you to a partner facility with crowded booths and minimal one-on-one coaching will shortchange the hands-on skill that AWS D1.1 testing actually demands.
Career Outlook: Where Structural Welding Jobs Are and What They Pay
Structural welding jobs sit inside the broader field of ironworking, the trade that fabricates and connects the steel skeletons of bridges, high-rises, and industrial plants. If you're weighing whether the time and money you'd spend on a program will pay off, wages and demand are the numbers that matter most.
According to national BLS data, structural iron and steel workers earned a median annual welder salary of about 62,780 dollars in 2025, with entry-level pay (the 10th percentile) around 44,580 dollars.1 For comparison, the broader construction and extraction category, which includes many welding-adjacent trades, reported a median of 59,540 dollars,2 so structural steel work tends to pay somewhat above the general construction average.
Growth Is Modest, Not Explosive
BLS projects total employment in this occupation to grow from about 68,300 workers in 2025 to 70,400 by 2035, a gain of roughly 2,100 jobs nationally, which BLS rounds to about 1 percent growth over the decade.1 That's slower than the outlook for construction occupations overall. The upside: retirements and turnover still generate an estimated 6,800 annual openings nationwide, so the job market stays active even without rapid expansion.1
State-Level Wage Data Is Thin Right Now
Current state-by-state and metro-level wage breakdowns for structural welders were not available in the most recent BLS release used here.1 Older regional figures exist but predate the current wage year, so treat any state-specific pay claims you find elsewhere with some caution until updated figures are published. What's consistent across sources is that heavy industrial and infrastructure hubs, ports, refineries, shipyards, and major metro construction markets, tend to concentrate the bulk of structural welding openings.
Running the ROI Math
Entry wages near 44,000 to 45,000 dollars1 and a typical program cost of a few thousand to around ten thousand dollars over a welding school duration of several months mean most students recover the investment within the first year or two of full-time work, assuming steady job placement and no major gaps in employment.
Structural Welding Certification Questions, Answered
The real tradeoff in structural welding certification is speed versus cost versus flexibility, and most of your questions come back to balancing those three. Here are straight answers to the ones we hear most.
How long does it take to become a certified structural welder?
Most dedicated programs run six to eighteen months for a certificate or a full associate degree. Add two to six weeks for the AWS D1.1 qualification test itself once your hands are ready. Career-changers with prior fabrication or ironworking experience sometimes qualify faster through direct testing.
How much does structural welding certification cost?
Expect $2,000 to $25,800 for tuition and equipment depending on the school, plus $200 to $500 for the performance qualification test. Community colleges and trade schools typically land at the lower end; private technical institutes run higher.
Can I earn structural welding certification fully online?
Online coursework can cover blueprint reading, metallurgy, and D1.1 code theory, but the hands-on welding and the qualification test itself must happen in person at an approved lab or testing facility. The strongest online programs partner with regional labs so you're not left arranging your own proctor.
What is AWS D1.1 certification?
AWS D1.1 is the structural welding code covering steel, and it's the qualification employers reference for bridge, building, and heavy-fabrication work. Certification means you've welded test coupons in specific positions and thicknesses and passed destructive or nondestructive evaluation.
Which certifications do employers actually require?
AWS D1.1 plate certification in the positions relevant to the job (often 3G and 4G for structural steel) is the baseline most fabricators and ironworker contractors expect. Some employers also want a CWI on staff for quality sign-off, though that's a separate, higher-level credential rather than something entry-level welders need immediately.
