Two welders can hit the same $50,000-plus median wage on completely different budgets: one graduates with a diploma and a stack of loan payments, the other finishes an apprenticeship with zero debt and four years of paychecks already banked. Welders, cutters, solderers, and brazers earn a national median wage of $53,750 a year according to the Bureau of Labor Statistics, but how you get into welding and fitting jobs shapes your finances for a decade.
Trade school compresses training into 7 to 24 months at a real cost, often $5,000 to $20,000, before you earn a dime. Apprenticeship stretches training to 3 to 5 years but pays a rising wage from the first day on the shop floor.
Neither path guarantees the same outcome, and admissions barriers, union access, and local demand all tilt the math differently depending on where you live.
Quick Comparison: Trade School vs Apprenticeship
Trade school is an upfront investment in a fast credential, while apprenticeships trade a longer timeline for paid on-the-job training. The right choice depends on how quickly you need income and how you learn best.
What Welding Trade School Actually Teaches
Classroom theory versus torch-in-hand practice: welding school is built to move you from one to the other as fast as safely possible.
Curriculum Basics
Most programs open with shop safety, PPE, and fire prevention before touching a machine. From there, students work through blueprint reading and welding symbols, basic metallurgy (how heat affects base metals and filler compatibility), and then the four core processes: shielded metal arc welding (stick), gas metal arc welding (MIG), gas tungsten arc welding (TIG), and flux-cored arc welding. Programs typically layer these in order of difficulty, starting with stick or flux-cored and finishing with TIG, which demands the most hand control.
Program Length and Format
Duration depends heavily on format. A full-time certificate program can run 6 to 12 months, while an associate degree that adds general education courses and advanced fabrication typically takes 18 to 24 months. Part-time and evening tracks stretch either option further, which matters for career-changers learning how to become a welder while keeping a day job. Check a school's page in the welding schools directory (/welding-schools/) for exact welding school duration before enrolling.
Certifications You Can Test For
Graduation itself isn't a credential. What matters is which tests a school prepares you to sit for:
- AWS D1.1: the structural steel welding code, common for construction and fabrication work.
- ASME Section IX: pressure vessel welding qualification, valuable for industrial and energy-sector jobs.
- AWS SENSE credentials: entry-level certifications that verify baseline competency for new welders entering the workforce.
The certification test guides (/welding-certification/) walk through what each exam actually covers and how to prepare.
Classroom vs Lab Time
Quality programs weight practice heavily: expect roughly 30 percent classroom instruction and 70 percent hands-on lab time. That ratio is worth confirming before you enroll, since employers and apprenticeship sponsors alike care more about logged welding hours and bead quality than lecture attendance.
What a Welding Apprenticeship Actually Looks Like (Union vs Nonunion)
A welding apprenticeship is a paid job from day one, not a classroom-first credential you earn before you start working.
Registered Apprenticeship Structure
A Registered Apprenticeship pairs on-the-job training with related classroom instruction, and it typically runs 3 to 5 years.1 Most programs require 6,000 to 8,000 hours of supervised OJT plus 400 to 600 hours of technical classroom work,1 though some extended or specialty tracks (shipyard welding apprenticeship programs are a common example, often running 4 to 5 years2) push past 8,000 OJT hours and add 1,000 or more classroom hours.3 You are logging hours and getting evaluated the entire time, not just showing up.
Wage Progression
Apprentices start at roughly 40 to 60 percent of the local journeyman rate1, with combination welders sometimes starting closer to 60 percent given the added skill demand. Raises typically land every 6 to 12 months4, often tied to roughly 1,000 additional OJT hours2 combined with classroom completion, skill demonstrations, or weld test results rather than time alone. By the final year, pay commonly reaches 80 to 90 percent3 of journeyman welding salary scale, hitting 100 percent1 at completion.
Union vs Nonunion Sponsors
Union apprenticeships, run through organizations like the UA or Ironworkers, follow a written wage schedule tied directly to the journeyman rate, with built-in contributions to health coverage, pension, and training funds. One 2026 union program, for example, lists apprentice pay around $20.35 an hour against a journeyman rate near $50.885, a spread that narrows steadily as the apprentice advances. Union tracks usually route classroom instruction through a joint labor-management training center, and application typically means testing into a hiring hall list rather than applying to a single employer.
Nonunion apprenticeships are sponsored directly by an employer, and pay, benefits, and progression rules are set by that company rather than a collective bargaining agreement. There is no single nonunion wage ladder: national apprentice pay in 2026 runs roughly $18 to $26 an hour6, and first-year annual pay commonly lands between $35,000 and $50,000, but raises can hinge on productivity, safety record, or a supervisor's judgment call as much as a fixed schedule.
Regional Variation Matters
Journeyman rates, and therefore apprentice pay, swing widely by metro area and specialty. A Philadelphia union track, for example, starts apprentices around 45 to 55 percent of scale and pushes to 80 to 90 percent by the final year, figures that will not match a nonunion shop in a lower cost-of-living market. Specialized journeyman work like code welding or offshore and pipeline jobs pays far above typical apprentice wages and reflects years of qualification, not an entry point.4
Welding School Costs vs Apprentice Pay: The Financial Trade-Off
The core tension between these two paths is simple: one asks you to pay up front and earn nothing while you train, the other pays you a wage from day one. Running the numbers on welding school cost before you commit is the single most useful thing you can do.
What Trade School Actually Costs
Tuition swings widely by program type and residency. Community college certificates commonly run $2,000 to $10,000, while private welding trade schools range from $5,000 to $35,800, and associate degrees fall between $10,000 and $30,000. Real 2026 examples show how much local pricing varies: Alvin Community College lists a total program cost near $1,986, Durham Technical Community College around $1,719, Carroll Community College about $3,173, and Southeast Community College roughly $8,382.
Then add the extras many catalogs bury or exclude:
- Tools and gear: Kits range from about $550 to $1,600 depending on the school. Southern Maine Community College lists a kit near $649, plus a $100 lab fee and a $56 certification fee.
- Fees and testing: Lab fees, books, and certification exams can add $500 to $3,000 across a full program.
- Transportation: Daily commuting to campus is an ongoing cost apprentices working locally may partly avoid.
Aid That Lowers the Bill
School cost is rarely the sticker price. Options to verify with each institution include:
- Pell Grants: For eligible students in qualifying programs, the 2025-2026 maximum award was $7,595; the amount depends on financial need and enrollment.
- GI Bill: For eligible veterans, this may cover full tuition plus a housing allowance at approved programs.
- Workforce vouchers: WIOA and local workforce boards fund training for qualifying applicants, though availability varies by area.
- Scholarships: School and industry scholarships can offset tuition, and some grants cover up to 100 percent.
Apprentice Earnings Over Time
An apprentice earns while learning. First-year pay commonly runs 40 to 50 percent of the journeyman rate, translating to roughly $20,400 to $25,500 in year one under a national example. Hourly pay steps up as skills grow: year two lands around $12.26 to $14.71 and year three around $14.71 to $17.16, with raises typically annual or semi-annual. One national model puts cumulative gross earnings at about $76,502 over three years and roughly $147,888 over five. Union scales run higher: one 2026 example starts apprentices at $20.35 an hour against a $50.88 journeyman rate.
These figures assume full-time hours, no overtime, and no unpaid classroom time, so treat them as estimates. All are gross, before taxes and any union dues.
A Simple Break-Even
Say you skip an $8,000 program plus $1,000 in tools to apprentice instead. That $9,000 avoided cost, added to a first-year wage near $22,000, puts an apprentice well ahead on paper by the end of year one. The school graduate can catch up later through faster certification and higher entry roles, but the early-year math favors earning while you learn.
Baton Rouge, LA has the highest median annual wage for welders, cutters, solderers, and brazers among metro areas, at $78,170. That is well above the national median for welders, making Baton Rouge one of the top-paying metros in 2025 BLS data.
Highest-Paying State for Welders
Alaska is the highest-paying state for welders, with a median annual wage of $80,840.
Welding Career Outcomes: Salary by State, Certifications, and Job Placement
This table shows median, mean, and top-quartile annual wages for welders, cutters, solderers, and brazers and for welding machine setters by state, based on the most recent federal occupational wage data. Certification portability is not one size fits all: an AWS Certified Welder credential is transferable if maintained, while employer-specific weld qualifications generally are not, and some states add extra requirements. Independent completion and job-placement data for welding programs remain scarce, so treat any single school's placement rate with caution.
| State | Occupation | Total Employment | Mean Annual Wage | Median Annual Wage | 75th Percentile Annual Wage |
| Alaska | Welders, Cutters, Solderers, and Brazers | 790 | 80100 | 80840 | 98500 |
| Hawaii | Welders, Cutters, Solderers, and Brazers | 520 | 77430 | 79000 | 90830 |
| Connecticut | Welders, Cutters, Solderers, and Brazers | 1790 | 66800 | 64880 | 81590 |
| Wyoming | Welders, Cutters, Solderers, and Brazers | 1850 | 67990 | 63820 | 78890 |
| Washington | Welders, Cutters, Solderers, and Brazers | 7720 | 66340 | 63020 | 73650 |
| Massachusetts | Welders, Cutters, Solderers, and Brazers | 2830 | 65050 | 62570 | 74050 |
| New Hampshire | Welders, Cutters, Solderers, and Brazers | 1110 | 62900 | 62360 | 74420 |
| Louisiana | Welders, Cutters, Solderers, and Brazers | 13690 | 63750 | 62250 | 77310 |
| Maine | Welders, Cutters, Solderers, and Brazers | 1690 | 61930 | 62220 | 69130 |
| North Dakota | Welders, Cutters, Solderers, and Brazers | 2590 | 64880 | 62000 | 72560 |
| Nevada | Welders, Cutters, Solderers, and Brazers | 1600 | 64590 | 61520 | 76670 |
| Vermont | Welders, Cutters, Solderers, and Brazers | 340 | 60210 | 60890 | 65490 |
| Maryland | Welders, Cutters, Solderers, and Brazers | 2850 | 64410 | 60310 | 77810 |
| Minnesota | Welders, Cutters, Solderers, and Brazers | 9270 | 60360 | 60280 | 65410 |
| District of Columbia | Welders, Cutters, Solderers, and Brazers | 280 | 61620 | 60180 | 75580 |
| New Mexico | Welders, Cutters, Solderers, and Brazers | 2390 | 63720 | 59840 | 82550 |
| Oregon | Welders, Cutters, Solderers, and Brazers | 5240 | 60390 | 59450 | 66570 |
| New Jersey | Welders, Cutters, Solderers, and Brazers | 3730 | 62500 | 59440 | 71060 |
| Virginia | Welders, Cutters, Solderers, and Brazers | 10100 | 60410 | 59180 | 65400 |
| New York | Welders, Cutters, Solderers, and Brazers | 8310 | 62810 | 59140 | 71960 |
| Colorado | Welders, Cutters, Solderers, and Brazers | 4970 | 60410 | 58590 | 69540 |
| Wisconsin | Welders, Cutters, Solderers, and Brazers | 15320 | 57920 | 58410 | 62220 |
| Utah | Welders, Cutters, Solderers, and Brazers | 4440 | 59640 | 58380 | 66870 |
| California | Welders, Cutters, Solderers, and Brazers | 26060 | 61120 | 58060 | 70400 |
| Delaware | Welders, Cutters, Solderers, and Brazers | 600 | 58470 | 57270 | 61630 |
| Arizona | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 280 | 68030 | 70150 | 77380 |
| Alaska | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 50 | 70110 | 62700 | 64630 |
| Washington | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 50 | 60410 | 58990 | 63830 |
| Illinois | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 180 | 61020 | 58840 | 63840 |
| Oregon | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 250 | 60220 | 58650 | 70390 |
| Wisconsin | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 1150 | 56140 | 57640 | 63340 |
| Minnesota | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 670 | 56670 | 57560 | 61340 |
| Nebraska | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 650 | 56740 | 57280 | 62480 |
| Missouri | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 560 | 55980 | 56210 | 60110 |
| New Jersey | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 510 | 52310 | 53680 | 62280 |
| South Dakota | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 150 | 51970 | 52520 | 56400 |
| New York | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 740 | 56230 | 52080 | 63760 |
| Iowa | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 1310 | 52530 | 51740 | 58080 |
| Texas | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 1750 | 52860 | 51310 | 59590 |
| Idaho | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 100 | 53610 | 50850 | 63650 |
| Kentucky | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 1000 | 52390 | 50740 | 59820 |
| Massachusetts | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 480 | 51550 | 50480 | 60610 |
| Rhode Island | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 160 | 52360 | 50040 | 61510 |
| Colorado | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 100 | 51890 | 49860 | 60560 |
| Virginia | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 410 | 49670 | 49160 | 55690 |
| California | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 2290 | 53170 | 48940 | 57950 |
| Louisiana | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 320 | 57500 | 48740 | 79160 |
| Maine | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 60 | 50080 | 48410 | 52830 |
| Ohio | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 2190 | 51130 | 48190 | 59560 |
| Connecticut | Welding, Soldering, and Brazing Machine Setters, Operators, and Tenders | 590 | 53440 | 47900 | 62110 |
- Fastest Welding Programs
